Papagayo 1.2 problems
Discuss Papagayo issues here
macweenie
Post by macweenie »
I just downloaded the most current version (1.2) of Papagayo and installed it on a Mac OS X (10.4.7) system and it won't even open. I have rebooted, reinstalled, rebooted yet again and it still won't open. Is this a known issue or am I doing something wrong? The 1.1 version opened fine so I am hoping this is an issue with Papagayo? :shock: :shock:
There's a new version out? I didn't even know!
I'll test it later, fortunately I have both Mac OS 10.4.7 and 10.4.6 available.
Lost Marble
Post by Lost Marble »
Intel or PPC?
ulrik
Post by ulrik »
I have the same problem, it will not launch.
I'm on ppc os 10.4.7
Lost Marble
Could one of you try something for me?
Run the Terminal app and type the following command and press enter:
python
You'll then get a new prompt that looks like this
At the new prompt this and press enter:
import wx
Please tell me what prints out in the terminal next (if anything).
Thanks.
ulrik
Post by ulrik »
Hi LM, I get nothing when writing import wx and hit enter, I only get a new prompt looking the same >>>
macweenie
Post by macweenie »
Sorry, just got back to check the forum. I use a PPC Mac and in a second I will give you the terminal results...
Last login: Tue Jul 18 14:01:57 on console
Welcome to Darwin!
Virus:~ eric$ python
Python 2.3.5 (#1, Mar 20 2005, 20:38:20)
[GCC 3.3 20030304 (Apple Computer, Inc. build 1809)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import wx
Hope it helps!
PS: The name of my machine is Virus (I don't HAVE a virus...) :D
Test results:
Papagayo 1.2 on G5 PPC Mac OS 10.4.7 with Python 2.3.5 doesn't start.
Papagayo 1.2 on G4 PPC Mac OS 10.4.6 with Python 2.2 doesn't start.
ulrik
Post by ulrik »
I tried papagayo on my macbook intel to, but it will not launch, and in terminal writing "import wx" nothing happens
Lost Marble
Sorry to worry anyone, but seeing nothing happen after typing wx is a good thing - the bad news would be if you saw an error saying the wx module was not found.
Does anyone have Apple's developer tools installed? I'd like to hear from anyone who does or does not, and whether there's a correlation between Papagayo working or not working.
Lost Marble
In the meantime, here's a link to the previous version for OS X:
http://www.lostmarble.com/downloads/pap ... os_1.1.zip
This is too bad - the new version runs reall ynicely on an Intel Mac (that is, if it runs at all).
macweenie
Post by macweenie »
I have the dev tools installed, but have never really used them. Tell me what you need done (specifically) and I will do it...
Oh yeah, I also meant to mention that even though my previous post shows that I have Python 2.3.5, I had installed Python 2.4 several months ago so I could run blender (not that I CAN run blender but that's another issue). I don't know why the version shows as 2.3.5 but I can assure you I did install 2.4 because if I hadn't blender would not run, and it does.
Lost Marble
No, I don't need you to try anything with the dev tools - I was just wondering if some component was requiring them to be present, but that doesn't seem to be the issue.
Can you try this in Terminal?
pythonw /Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py
Let's see if that spits out an error message.
Thanks.
macweenie
Post by macweenie »
I'm getting this:
Last login: Wed Jul 19 18:30:14 on ttyp1
Welcome to Darwin!
Virus:~ eric$ pythonw /applications/papagayo/papagayo.app/contents/resources/papagayo.py
/Library/Frameworks/Python.framework/Versions/2.4/Resources/Python.app/Contents/MacOS/Python: can't open file '/applications/papagayo/papagayo.app/contents/resources/papagayo.py': [Errno 2] No such file or directory
Virus:~ eric$
However, does capitalization count here? It usually doesn't on a Mac but this is Unix no?
PS: I re-installed version 1.1 earlier today, should I re-install 1.2 before I run the test?
ulrik
Post by ulrik »
Lost Marble wrote:No, I don't need you to try anything with the dev tools - I was just wondering if some component was requiring them to be present, but that doesn't seem to be the issue.
Thanks.
I tried it and got this:
Ulrik-Bod-ns-dator-2:~ ulrikboden$ pythonw /Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py
2006-07-20 00:39:49.108 Python[484] CFLog (21): Error loading /Library/QuickTime/Motion.component/Contents/MacOS/Motion: error code 4, error number 0 (Library not loaded: /Library/Frameworks/Motion.framework/Versions/A/Motion
Referenced from: /Library/QuickTime/Motion.component/Contents/MacOS/Motion
Reason: image not found)
2006-07-20 00:39:49.117 Python[484] CFLog (21): Error loading /Library/QuickTime/Motion.component/Contents/MacOS/Motion: error code 4, error number 0 (Library not loaded: /Library/Frameworks/Motion.framework/Versions/A/Motion
2006-07-20 00:39:49.124 Python[484] CFLog (21): Error loading /Library/QuickTime/Motion.component/Contents/MacOS/Motion: error code 4, error number 0 (Library not loaded: /Library/Frameworks/Motion.framework/Versions/A/Motion
and the "python" papagayo launched
