https://youtu.be/2J8mWR8ihG0?si=tNzIN_RomdpiZK7N
Hello. This is a project I'm developing called Motion Preset. This tool has 45 effects that I programmed myself, divided into 5 main groups: Basic with sliding, blurring, and bouncing effects; Physics with motion simulations of falling, bouncing, and collisions; Special Effects with fragmentation and 3D flip effects; Motion Loop with infinite shaking effects; and Text FX specializing in creating text typing and matrix decoding effects. To use it, simply select one or more layers on the Timeline, open the tool, and choose any effect from the list. Next, select IN (flying in) or OUT (flying out) mode, set the direction of movement, start time, and delay between layers if desired. Finally, just press the Apply button to apply. Afterward, you can play the Timeline to see the result or press Ctrl + Z to undo and try a different effect. I'm currently in the development process, and I would be very happy if everyone likes and enjoys it.
Animation Preset Toolkit for MOHO ⭐
Re: Animation Preset Toolkit for MOHO ⭐
Well, let us know when or if it become available.
synthsin75 wrote: ↑Sun Jul 19, 2026 10:57 pm Well, let us know when or if it become available.
Thanks! I'm planning to release it in August. I'll share an update once it's available. Appreciate your interest!
That looks pretty cool!
Good luck!
Good luck!
Hi everyone! Following up on the demo video I shared earlier, Motion Presets Pro v4.00 for Moho Pro is officially available now.
The tool allows you to apply over 47 motion presets (physics bounce, leaf fall, shatter/assemble, text stagger...) to vectors, images, text, and groups with just one click, saving you from spending hours adjusting graph curves manually. It supports dual IN/OUT trajectories, additive effect stacking, and customizable bake or bezier keyframes.
You can learn more and get the tool here: https://czmotion.pages.dev/
I would love to hear your feedback and suggestions. I hope you find it useful and enjoy using it!
This is $50.
Yes, the full version is $50.
