BlenderLipSynchro V2 Release!
Discuss Papagayo issues here
dienben
Post by dienben »
Hello,
Great news today! I release a new version of blenderlipsynchro! This is a blender script to use papagayo and Blender!
The imrovement:
- framework simplified! You only have to choose the export file from your favorite lipsynchronisation application and made the mapping
- mutli phonems set supported! You are not depend from any pre defined phonems set, like the Preston Blair one or JLipSync one. You could use your own custom phonems set.
- phonems auto detection : you have just to mapp the used phonems. For exemple, if you use 15 phonems and in a particular scene only 8, you just map 8 phonems.
- true compatibility with any lipsynchronisation tool: open source, of cousre (papagayo, pamela and JLipSync), and the ones who export for moho. The interface is very simple: the first line of the text file is not intepreted, and then, for each line, you write the number of the frame, a space and the phonem use at this frame.That's all. A simple text editor is suffisant!
Technically:
- non regression test suit
- code cleaning
My target is efficiency. So less clicks and simple function.
D'ont forget to create your Ipo curves befor use the script. If you don't, the script simple remin it to you!
The links:
my blog:
http://blenderlipsynchro.blogspot.com/
the script:
http://afn.dalmont.free.fr/ben/blenderl ... Synchro.py
the non regression suit:
http://afn.dalmont.free.fr/ben/blenderl ... o2/nonreg/
Cheer!
Dienben
bupaje
Post by bupaje »
Hi. I have not used Blender yet but sounds interesting. Congratulations and thanks for your work.
