Came across this funky display issue on Moho 14.4 when using an external display on Mac. Posting here first, just to see if anyone else has had a similar experience.
I'm convinced its a problem with display scaling, don't recall having it when using other displays while on mac. And it’s only menus that need an action to open. Haven’t been able to test myself on Windows, but others have said they don’t get this (tried using same display/settings). Could literally just be big screen being weird. If I click a different layer while its open it goes away, if I click a tab on the same layer it stays but boots itself behind, But if I open on the main screen and drag across its all good! In short - it does nothing just looks hella funky.
https://drive.google.com/file/d/1ufyla- ... drive_link
https://drive.google.com/file/d/1I-Jvb7 ... drive_link
All windows effected:
- Export Animation Menu
- Project Settings
- Grid settings
- Layer Settings
- switch selection
Using either the Mac display or Cintiq display has scaling issues. Whatever screen is set to be the extended display is effected. (Wacom Cintiq 22 connected via cables set to 1920x1080, main Mac display set to 1728 x 1117), when mirroring the screen via cables to Cintiq or to an Ipad, everything works as normal.
So where the non-docked windows appears effect the scaling.
It may be much smaller than usual or absolutely huge (depending on screen resolution).
Its completely visual though, has no effect / cannot click the fields.
This is present only in 14.4, on 14.3 it seems fine- cannot replicate it, so am pretty sure its a 14.4 issue?
Have gone through Apple and Wacoms display settings and nothing seems to help.
Another minor thing I'm curious of:
- Styles window when undocked gets cropped off on display set as Main, it is not present on displays set to extended. Ive tried different displays, and it seems to just be based on if the window is undocked or not. This is present in 14.3 and 14.4.
https://drive.google.com/file/d/1smq_sr ... drive_link
Thanks!
Moho 14.4 Mac Display Bug
Nicholas Mitchell
Re: Moho 14.4 Mac Display Bug
FYI. Your shared files are not accessible.
Nicholas Mitchell
Ah! Updated Now
That looks kinda funky. Never seen that before. I would def report it to LM Support: https://lostmarble.com/support/
