Can't get the ParentSkeleton anymore
Just curious about
moho:ParentSkeleton()
It doesn't seem to work anymore. Been fixing up and playing around with some old scripts and for the life of me this doesn't work. Can't get bones from the parent skeleton. Assigning parentskeleton to a variable is always nil or null empty. It was working... uh... er... many versions ago. Probably version 9.
I keep finding references to this in some scripts:
	local parentSkeleton = false
	local skel = moho:Skeleton()
	if (skel == nil) then
		if (self:ShouldUseParentSkeleton(moho)) then
			skel = moho:ParentSkeleton()
			parentSkeleton = true
		end
			return
		end
	end
Is there a "new" way to access the parent skeleton? One extra bit of info, the script looking for the parent skeleton is a bone layer. I need to transfer movement of a bone in a sub layer to a bone in the parent bone layer.
Re: Can't get the ParentSkeleton anymore
This always happens. As soon as I ask I find a solution.
It appears that yes, maybe possibly there have been changes that affected how to access a parent skeleton and broke some of my old scripts The solution is to get
local pLayer = layer:Parent()
convert it to a bone skeleton reference;
local pSkel = moho:LayerAsBone(pLayer):Skeleton()
A wee bit "round-aboutie" but it works. If there's an easier way let me know.
SimplSam
Post by SimplSam »
moho:ParentSkeleton() - should return the controlling Skel of the currently selected layer.
layer:ControllingSkeleton(), would return the controlling Skel of the specified layer.
Note: moho:Skeleton will also return a Skeleton for empty Bone Layers, Switch Layers and FBF Layers - if they are the currently selected layer.
Also note: The controlling bone layer is not always the immediate parent layer. Could be a grandparent etc.
Thanks for the feedback. It works now!!!!! I haven't figured out where I went wrong or what was causing the error, but some of the code must have been botched up, and NOW ParentSkeleton works perfectly.
I have some clues on what was wrong after making some changes to update the script. The dang script is 15 years old! Holy cow, I'm FREAKING OLD.
I resurrected it because long before targeted bones native in Moho, I scripted my own version. I was trying to recreate my script using the built-in targeted bone tools, but it appears my script... uh... er... has better features than the built-in tools. I am using this scripted version to have a reference to find a way to replicate my scripted bone targets with the built-in targeted bones. I've gotten close but not quite there yet.
The one cool thing my script does I can't quite replicate with the built-in targeting, is scaling down and up. In the bone settings, you can set the percentage of STRETCH only. Mine works by allowing scaling of any number of bones in a chain, both above and below the actual length of the bone and doesn't require any percentage set. The target bone both stretches and compresses the bone it controls, but does not interfere with the angle of that bone in the hierarchy.
For example, a leg in a walk or run cycle has a bend at the knee. I can target the calf to the foot and stretch, shrink, or rotate just the calf, and it has no effect on the thigh wich also has a target that can stretch, shrink, or change the angle of the thigh. It's awesome and allows some wicked cool exaggerated squash and stretch.
I am almost certain I should be able to replicate this with some sort of "out of the box" way of creating limb bone chains. Maybe with odd parenting, that isn't a basic chain like a standard leg or arm.
Okay, just rambling now. Anyway, parentskeleton is working again, thanks for listening. :)
