Do Fazek's scripts work in the Windows version?
If they do, how do I install them?
Thanks,
Howard
2 script questions
writerhoward
1. Yes.
2. All systems has a folder where Moho installed, on Windows typically in the 'C:\Program Files\Moho'. In this folder there's a 'scripts' folder, and in the 'scripts' folder there are 'tool' and 'utility'. So download the file from http://www.firkafilm.com/moho/, unzip them (With XP, you can go into the zip file, like a folder) and copy everything into the right place ie. the contents of the 'tool' to the Moho's 'tool' folder etc. After this, if you start Moho, you will see the new tool buttons on the Tools window, at the bottom, in an "Other" group.
- - - Fazek
writerhoward
Reply to Fazek
Thanks. It was easy to install your scripts.
Howard
Howard
