VOVANIMATION
- vovanimation
- vovanimation
really thank you!
your work inspires to me.
you use moho in a very intelligent way. and i have some doubts. technical doubts, for example, in the file kot.moho there is a red vertical line wich is marked to no be rendered. what is this line?
i noticed too you never used masks. is there a big reason? (maybe, mmm, to export to flash. i don't know, i never export to flash). and you never use constraints bones either.
well, i'll see the files again. i'm learning a lot.
thanks
thanks
- vovanimation
Thank!
I use all opportunities Moho, both mask, and constraints bones, there where it is necessary.
The red line at the cat is simple the centre of an eye, nose, mouth, for convenience of construction and rotation of an inclination of a head!
These Moho files the tests, instead of final variants for production...
Moho files for ready manufacture I shall not spread, business secret.
- vovanimation
- vovanimation
Yes, I work on different studios, free-lance.
The own project in Russia, in Moscow, while is not present good Producer and investor.
And at the expense of the state, long to wait.
Simply link Russia animation
http://www.multiskazka.ru/about
Very nice work. I particularly like your cartoon style.
Alan
Alan
Get some "Good Advice" at www.decksawash.net
- vovanimation
I also have written that IT IS the TESTS FOR the DIFFERENT COMPANIES to me have sent this character and asked to make simply TEST ON MOHO!!!
I make animation, and not always as the designer of the characters!!!
And I has received order on this test from http://bartsoft.com/projects_mov.htm
And this company at all has not told whose it is the character!!!
Moho
Moho
