Hey Guys, here's a short video displaying an issue I'm having with a rig. Any feedback would be appreciated.
https://youtu.be/WYv5CmIW9QE?si=EPcBJERCaIi0EVH0
File:
https://www.dropbox.com/scl/fi/8oz2rslz ... nu9py&dl=0
Rig issue. Need help.
- Yosemite Sam
Jimmy Mills
Some of my Moho Pro work.
Re: Rig issue. Need help.
There's negative keyframes.
Run my menu script to fix it: viewtopic.php?t=32714
This is a known issue.
- Yosemite Sam
Damn, Wes, you're good! Worked, thanks!synthsin75 wrote: ↑Wed Oct 22, 2025 8:32 pm There's negative keyframes.
Jimmy Mills
Cheers.
It is hard to see how you structured and binded your layers. But it looks like you have not binded the layer properly or you may binded points without linking the layers to the bone. Or maybe you have negative keyframes or you freeze points that is not necessary in the action timeline.
- Yosemite Sam
Thanks for taking a look, Panha. It was negative keyframes. Wes' script fixed it.Panha wrote: ↑Wed Oct 22, 2025 9:11 pm It is hard to see how you structured and binded your layers. But it looks like you have not binded the layer properly or you may binded points without linking the layers to the bone. Or maybe you have negative keyframes or you freeze points that is not necessary in the action timeline.
I hate that rig I posted. It was the first one I created back in 2011 when I was just starting out. In anime Studio 7, I believe. But the channel for that show has a lot of fans, and I've been too lazy to go back and update all the characters. Hopefully, one day, because not only is it messy, but I can't imagine it serves me to use a rig created in AS 7 on Moho 14, almost 15 years later.
Jimmy Mills
