Batch change frame duration of imported image sequence
kakubei
Post by kakubei »
So, I know that if I import an image sequence and then change the layer to Switch, it creates a frame by frame animation with those images. That's great.
What I'm wondering is if there is a way to change the duration of all those imported images easily.
My problem is I do a lot of my roughs in Rough Animator at 12 fps. Then I import that into Moho as a reference to do the actual animation.
In After Effects, there is this handy Interpret Footage command which allows you to change the frame rate of the imported sequence. I change it to 24 fps and boom, good to go!
Is there something similar I can do in Moho?
Thanks.
Re: Batch change frame duration of imported image sequence
Definitely! I asked that myself since it's part of my everyday workflow.
Ah, just discovered that it's there, albeit a bit hidden and clumsy.
- Import image sequence
- Select that layer and convert to switch
- Animation -> Rescale Keyframes. Select Switch, type in new end frame number.
SimplSam
Post by SimplSam »
- After importing using: File > Import Image Sequence
- Go to the layer properties, and under the Image tab, you will be able to set the frame rate
Generally, if you import Image Sequences or GIF animations, they are treated like Video files.
Ah, another way. I will keep mine since I often have irregular timing and need access to single switch keys.
kakubei
Post by kakubei »
Thank you very much for this!
