Script: Copy Previous Camera Frame to the current Cursor, made by ChatGPT
If you use track and zoom camera alot like I do, you may find this copy previous track and zoom camera useful. Most of the time. Before when I want to freeze the camera key, I had to click on the camera, and click on the canvas to create the keyframe. There may be other ways easier than this that I missed. However, I asked ChatGPT to create a script for me to freeze the camera key that I most often use in my animaton, track and zoom camera. So here is the script. It works just find and as expected. https://drive.google.com/file/d/1sabjg9 ... drive_link
Re: Script: Copy Previous Camera Frame to the current Cursor, made by ChatGPT
Interesting...I'll check it out later today! Thanks for sharing!
I tried using it and found it ineffective. In fact, just using camera number 4 is sufficient, so why did that tool add camera number 5? Using two cameras at the same time makes the camera very uncomfortable.Panha wrote: ↑Sun Aug 31, 2025 9:36 pm If you use track and zoom camera alot like I do, you may find this copy previous track and zoom camera useful. Most of the time. Before when I want to freeze the camera key, I had to click on the camera, and click on the canvas to create the keyframe. There may be other ways easier than this that I missed. However, I asked ChatGPT to create a script for me to freeze the camera key that I most often use in my animaton, track and zoom camera. So here is the script. It works just find and as expected. https://drive.google.com/file/d/1sabjg9 ... drive_link
That's mostly what I do all the time. I use Camera 4 and 5 most of the time. For example, when I want to cut scene or zoom in/out quickly. Anyway, you can customize the code, and share it too.congz wrote: ↑Tue Sep 02, 2025 9:20 pmI tried using it and found it ineffective. In fact, just using camera number 4 is sufficient, so why did that tool add camera number 5? Using two cameras at the same time makes the camera very uncomfortable.Panha wrote: ↑Sun Aug 31, 2025 9:36 pm If you use track and zoom camera alot like I do, you may find this copy previous track and zoom camera useful. Most of the time. Before when I want to freeze the camera key, I had to click on the camera, and click on the canvas to create the keyframe. There may be other ways easier than this that I missed. However, I asked ChatGPT to create a script for me to freeze the camera key that I most often use in my animaton, track and zoom camera. So here is the script. It works just find and as expected. https://drive.google.com/file/d/1sabjg9 ... drive_link
Thank you, and if you find it does not right to your workflow, you can customize it to your like.
“You only need to use Camera 4 to pan and zoom; there’s no need to use Camera 5. Using two cameras at the same time is really unprofessional, causes lag, and makes the camera movement path look messy and unattractive.”Panha wrote: ↑Sun Sep 07, 2025 7:43 pmThat's mostly what I do all the time. I use Camera 4 and 5 most of the time. For example, when I want to cut scene or zoom in/out quickly. Anyway, you can customize the code, and share it too.congz wrote: ↑Tue Sep 02, 2025 9:20 pmI tried using it and found it ineffective. In fact, just using camera number 4 is sufficient, so why did that tool add camera number 5? Using two cameras at the same time makes the camera very uncomfortable.Panha wrote: ↑Sun Aug 31, 2025 9:36 pm If you use track and zoom camera alot like I do, you may find this copy previous track and zoom camera useful. Most of the time. Before when I want to freeze the camera key, I had to click on the camera, and click on the canvas to create the keyframe. There may be other ways easier than this that I missed. However, I asked ChatGPT to create a script for me to freeze the camera key that I most often use in my animaton, track and zoom camera. So here is the script. It works just find and as expected. https://drive.google.com/file/d/1sabjg9 ... drive_link![]()
[/quote]
[/quote]
It's the way I track and zoom the scene for my animation. I have done this for more than 200 episode of my animations. You may have your own methods of working with Camera. However, using only a zoom camera would not make sense to me since most of the time, I need both zoom and track to capture the scene and the subject with the scenes. I don't know how could you use only zoom camera to work with a whole animation, but it you can do that, it would be strange to me.
[/quote]
Sounds like he's just uses track camera (4) to track in and out, instead of zoom. If you're not making a multi-plane set up, for parallax or depth of field at different z-depths, that would work.Panha wrote: ↑Fri Sep 19, 2025 10:23 pmIt's the way I track and zoom the scene for my animation. I have done this for more than 200 episode of my animations. You may have your own methods of working with Camera. However, using only a zoom camera would not make sense to me since most of the time, I need both zoom and track to capture the scene and the subject with the scenes. I don't know how could you use only zoom camera to work with a whole animation, but it you can do that, it would be strange to me.“You only need to use Camera 4 to pan and zoom; there’s no need to use Camera 5. Using two cameras at the same time is really unprofessional, causes lag, and makes the camera movement path look messy and unattractive.”![]()
[/quote]
[/quote]
“Hold Alt + Camera 4 if you want to zoom, and release Alt if you want to pan or track the camera. This is a quick and efficient method without needing to use Camera 5. Even if you set the depth of the scene, using Camera 4 will not be affected.”
You can combine those two things in one camera number 4
