only show the parent arrows for the selected bone?
tifacloud7
Post by tifacloud7 »
Hi everyone! I'm pretty new to Moho . :oops:
I haven’t been able to find much info or tutorials on this, so I thought I’d make a post and ask here. Really appreciate your time and any help you can offer!
So, I’m wondering — is there a way to make the parent arrows on bones smaller, or only show the parent arrows for the bone I have selected?
When I’m working on more complex rigging, the parent arrows sometimes get in the way and block the bones I’m trying to click on. It gets a bit tricky to work with.
I’ve tried using the “Toggle Color Bones” script to hide the bones I don’t need, but their parent arrows still show up even when the bones are hidden.
Just wondering how you all deal with this?
Would love to hear any tips or workarounds. Thanks so much in advance!
Image "There are arrows all over the place!" :x
Re: only show the parent arrows for the selected bone?
You can keep any bone invisible by making it a shy bone (and reverse that, of course). This is useful f you have a rig with many small bones cluttering your view.
slowtiger wrote: Thu May 22, 2025 1:50 am You can keep any bone invisible by making it a shy bone (and reverse that, of course). This is useful f you have a rig with many small bones cluttering your view.
I think that just hides the bone, not the parenting arrows? (same as hiding coloured bones).
tifacloud7
Thanks so much for all the replies!
You're right — when using the Shy Bone tool to hide bones, as soon as I switch to the Reparent Bone tool, all the parent arrows still show up — including those from the hidden bones. It really gets in the way and makes things difficult. :cry:
I’m also wondering — is there a tool or option that lets me choose the parent bone from a menu or list, instead of clicking directly in the viewport? :?:
Because right now, the arrows are covering so many bones that I can’t clearly see or select the one I want. :x
A quick mod of the reparent bone tool:
ScriptName = "LM_ReparentBone"
LM_ReparentBone = {}
LM_ReparentBone.BASE_STR = 2230
function LM_ReparentBone:Name()
	return "Reparent Bone"
end
function LM_ReparentBone:Version()
	return "6.0"
end
function LM_ReparentBone:Description()
	return MOHO.Localize("/Scripts/Tool/ReparentBone/Description=Click to attach bone to a new parent (hold <alt> to select a new bone, <ctrl/cmd> to select a target bone)")
end
function LM_ReparentBone:Creator()
	return "Lost Marble LLC"
end
function LM_ReparentBone:UILabel()
	return(MOHO.Localize("/Scripts/Tool/ReparentBone/ReparentBone=Reparent Bone"))
end
-- The guts of this script
function LM_ReparentBone:IsEnabled(moho)
	if (moho:CountBones() < 2) then
		return false
	end
	if (moho.frame > 0 and not MOHO.IsMohoPro()) then
		return false
	end
	return true
end
function LM_ReparentBone:IsRelevant(moho)
	local skel = moho:Skeleton()
	if (skel == nil) then
		return false
	end
		return false
	end
	return true
end
function LM_ReparentBone:OnMouseDown(moho, mouseEvent)
	moho.document:PrepUndo(moho.layer, true)
	moho.document:SetDirty()
	self:OnReparent(moho, mouseEvent)
end
function LM_ReparentBone:OnMouseMoved(moho, mouseEvent)
end
function LM_ReparentBone:OnMouseUp(moho, mouseEvent)
	moho:UpdateUI()
end
function LM_ReparentBone:OnKeyDown(moho, keyEvent)
	LM_SelectBone:OnKeyDown(moho, keyEvent)
end
function LM_ReparentBone:DrawMe(moho, view)
		return
	end
	local g = view:Graphics()
	local matrix = LM.Matrix:new_local()
	local bonePt = LM.Vector2:new_local()
	local parentPt = LM.Vector2:new_local()
	local arrowPt1 = LM.Vector2:new_local()
	local arrowPt2 = LM.Vector2:new_local()
	moho.layer:GetFullTransform(moho.frame, matrix, moho.document)
	g:Push()
	g:ApplyMatrix(matrix)
	g:SetSmoothing(true)
	for i = 0, skel:CountBones() - 1 do
		local bone = skel:Bone(i)
		--if (bone.fParent >= 0) then
--[[syn]]	if (bone.fParent >= 0) and (bone.fSelected or skel:Bone(bone.fParent).fSelected)--[[(not bone.fHidden)]] then
			local parentBone = skel:Bone(bone.fParent)
			bonePt:Set(bone.fLength / 2, 0)
			if (moho.frame > 0) then
				bone.fMovedMatrix:Transform(bonePt)
			else
				bone.fRestMatrix:Transform(bonePt)
			end
			parentPt:Set(parentBone.fLength / 2, 0)
				parentBone.fMovedMatrix:Transform(parentPt)
			else
				parentBone.fRestMatrix:Transform(parentPt)
			end
			local v = parentPt - bonePt
			local mag = v:Mag()
			local f = mag
			if (f > 0.2) then
				f = 0.2
			end
			arrowPt1:Set(mag - f / 4, -f / 16)
			arrowPt2:Set(mag - f / 4, f / 16)
			f = math.atan(v.y, v.x)
			arrowPt1:Rotate(f)
			arrowPt2:Rotate(f)
			arrowPt1.x = arrowPt1.x + bonePt.x
			arrowPt1.y = arrowPt1.y + bonePt.y
			arrowPt2.x = arrowPt2.x + bonePt.x
			arrowPt2.y = arrowPt2.y + bonePt.y
			if (bone.fSelected) then
				g:SetColor(MOHO.MohoGlobals.SelCol)
			else
				g:SetColor(MOHO.MohoGlobals.ElemCol)
			end
			g:DrawLine(bonePt.x, bonePt.y, parentPt.x, parentPt.y)
			g:BeginShape()
			g:AddLine(parentPt, arrowPt1)
			g:AddLine(arrowPt1, arrowPt2)
			g:AddLine(arrowPt2, parentPt)
			g:EndShape()
		end
	end
	g:Pop()
end
function LM_ReparentBone:OnReparent(moho, mouseEvent)
	if (mouseEvent.altKey) then
		LM_SelectBone:Select(moho, mouseEvent.pt, mouseEvent.vec, mouseEvent.view, mouseEvent.shiftKey, mouseEvent.ctrlKey)
		return
	end
		return
	end
	if (moho:CountSelectedBones() < 1) then
		return
	end
	-- let the user pick another bone - this will be the new parent
	local parentID = mouseEvent.view:PickBone(mouseEvent.pt, mouseEvent.vec, moho.layer, true)
	local parentFrame = moho.layerFrame -- 0
	if (mouseEvent.ctrlKey) then
		local targetChanged = false
			if (bone.fSelected and parentID ~= bone.fTargetBone:GetValue(moho.layerFrame)) then
				bone.fTargetBone:SetValue(moho.layerFrame, parentID)
				targetChanged = true
			end
		end
		if (targetChanged) then
			moho:NewKeyframe(CHANNEL_BONE_TARGET)
		end
	else
				if (not skel:IsBoneChild(i, parentID)) then
					-- new parent chosen
					local v1 = LM.Vector2:new_local()
					local v2 = LM.Vector2:new_local()
					v1:Set(0, 0)
					if (bone:IsZeroLength()) then
						v2:Set(0.1, 0)
					else
						v2:Set(bone.fLength, 0)
					end
						bone.fMovedMatrix:Transform(v1)
						bone.fMovedMatrix:Transform(v2)
					else
						bone.fRestMatrix:Transform(v1)
						bone.fRestMatrix:Transform(v2)
					end
					if (parentID >= 0) then
						local invMatrix = LM.Matrix:new_local()
						local parent = skel:Bone(parentID)
							invMatrix:Set(parent.fMovedMatrix)
						else
							invMatrix:Set(parent.fRestMatrix)
						end
						invMatrix:Invert()
						invMatrix:Transform(v1)
						invMatrix:Transform(v2)
					end
					if (parentFrame ~= 0) then
						bone.fAnimPos:AddKey(parentFrame - 1)
						if (bone:ParentalFlipFactor() < 0.0) then
							bone.fFlipV:SetValue(parentFrame, not bone.fFlipV:GetValue(parentFrame))
						end
						bone.fAnimPos:SetValue(parentFrame, v1 - bone.fOffset)
					else
						bone.fAnimPos:SetValue(parentFrame, v1)
					end
					v2 = v2 - v1
					local angle = math.atan(v2.y, v2.x)
					while angle > 2 * math.pi do
						angle = angle - 2 * math.pi
					end
					while angle < 0 do
						angle = angle + 2 * math.pi
					end
					if (bone.fFixedAngle) then
						if (parentFrame == 0) then
							bone.fAnimAngle:SetValue(parentFrame, angle)
						end
					else
						local angleDiff = angle - bone.fAnimAngle:GetValue(parentFrame)
							bone.fAnimAngle:AddKey(parentFrame - 1)
						end
						-- update future angle keyframes for relative offsets just like this frame
						for keyID = 0, bone.fAnimAngle:CountKeys() - 1 do
							local angleFrame = bone.fAnimAngle:GetKeyWhen(keyID)
							if (angleFrame > parentFrame) then
								local newAngle = bone.fAnimAngle:GetValue(angleFrame) + angleDiff
								bone.fAnimAngle:SetValue(angleFrame, newAngle)
							end
						end
						if (parentFrame == 0) then -- update action keyframes for relative offsets just like this frame
							for actionID = 0, bone.fAnimAngle:CountActions() - 1 do
								local action = moho:ChannelAsAnimVal(bone.fAnimAngle:Action(actionID))
								for keyID = 0, action:CountKeys() - 1 do
									local angleFrame = action:GetKeyWhen(keyID)
										local newAngle = action:GetValue(angleFrame) + angleDiff
										action:SetValue(angleFrame, newAngle)
									end
								end
							end
						end
					end
					if (bone.fAnimParent:CountKeys() < 2) then
						bone.fAnimParent:SetValue(0, bone.fParent)
					end
					bone.fParent = parentID
					bone.fAnimParent:SetValue(parentFrame, parentID)
						end
					end
				end
			end
		end
		moho:NewKeyframe(CHANNEL_BONE)
		moho:NewKeyframe(CHANNEL_BONE_T)
		moho:NewKeyframe(CHANNEL_BONE_PARENT)
	end
	moho.layer:UpdateCurFrame()
	mouseEvent.view:DrawMe()
	moho:UpdateSelectedChannels()
end
-- Tool options - create and respond to tool's UI
LM_ReparentBone.CHANGE = MOHO.MSG_BASE
LM_ReparentBone.DUMMY = MOHO.MSG_BASE + 1
LM_ReparentBone.SELECTITEM = MOHO.MSG_BASE + 2
function LM_ReparentBone:DoLayout(moho, layout)
	self.menu = LM.GUI.Menu(MOHO.Localize("/Scripts/Tool/ReparentBone/SelectBone=Select Bone"))
	self.popup = LM.GUI.PopupMenu(128, false)
	self.popup:SetMenu(self.menu)
	layout:AddChild(self.popup)
end
function LM_ReparentBone:UpdateWidgets(moho)
		return
	end
	MOHO.BuildBoneMenu(self.menu, skel, self.SELECTITEM, self.DUMMY)
end
function LM_ReparentBone:HandleMessage(moho, view, msg)
		return
	end
	if (msg >= self.SELECTITEM) then
			skel:Bone(i).fSelected = (i == msg - self.SELECTITEM)
		end
		moho:UpdateUI()
	end
end
This will only show the arrow of the selected bone and its parent bone.
tifacloud7
synthsin75 wrote: Thu May 22, 2025 6:52 pm A quick mod of the reparent bone tool:
end
	return "6.0"
end
end
end
end
		return false
	end
		return false
	end
	return true
end
		return false
	end
		return false
	end
	return true
end
end
end
	moho:UpdateUI()
end
end
		return
	end
	g:Push()
			else
			end
			else
			end
			local mag = v:Mag()
			local f = mag
			if (f > 0.2) then
				f = 0.2
			end
			arrowPt1:Rotate(f)
			arrowPt2:Rotate(f)
			else
			end
			g:BeginShape()
			g:EndShape()
		end
	end
	g:Pop()
end
		return
	end
		return
	end
		return
	end
			end
		end
		end
	else
					v1:Set(0, 0)
						v2:Set(0.1, 0)
					else
					end
					else
					end
						else
						end
						invMatrix:Invert()
					end
						end
					else
					end
					v2 = v2 - v1
					end
					while angle < 0 do
					end
						end
					else
						end
							end
						end
									end
								end
							end
						end
					end
					end
						end
					end
				end
			end
		end
	end
end
end
		return
	end
end
		return
	end
		end
		moho:UpdateUI()
	end
end
Thank you so much for your reply! I’m really excited to try it out right away!
But I’m so sorry—I’m not quite sure where I should paste the code you provided.
Would you mind explaining a little bit more? Sorry for the trouble! 🙏 :oops:
(I know how to install scripts, but I’m not sure how to install or run this kind of code ><)
This is a mod, which means it replaces the native tool. But don’t replace the file in your program folder! Instead, you need to make a copy of the original tool and place it in your Custom Content Folder.
I haven’t done this with this script, but normally, you can copy the original script and button icons from the Program folder to the Script>Tools folder in your Custom Content Folder. Then, using a text editor, paste this into that file to replace its content. When you run Moho, Moho will load this version of the tool instead of the native one. (Or, press Ctrl+Alt+Shift+L to reload scripts.)
If the mod doesn't work for you, you can remove the file from the Custom Content Folder, and Moho will resume using the native version upon relaunch. (FYI, I like to make a folder called 'Disabled' and move scripts I want to disable there. Moho will ignore scripts inside folders it doesn’t recognize. Then, if I decide to try it again later, I can move the files back into the Custom Content Folder’s Scripts>Tools folder.
It’s also possible to load this as a separate tool, so you have both available. But let’s take it one step at a time.
@Wes…this sounds interesting. Will try it out tonight.
If this is something more people might use, I'll package it up with a different name, so you can install it normally and still have the native tool available.
I only changed one line of the code, so I'm not sure it warrants being it's own tool just for that.
tifacloud7
synthsin75 wrote: Fri May 23, 2025 3:55 pm If this is something more people might use, I'll package it up with a different name, so you can install it normally and still have the native tool available.
Thank you so much for your detailed and professional reply!
This parent arrow issue has really been bothering me, and I honestly didn’t expect that just changing one line of code could fix it :shock:
If it’s okay to ask—could you kindly let me know where exactly I should go to change that line of code? :oops:
Hi,
If you load the original script and the mod into Notepad++ and run Compare, the added line appears at around line 99.
As mentioned earlier, you should not change the script in the Programs folder. Be sure to add the modified script to your Custom Content Folder instead.
IMO, it would be easier to copy the original script to the Custom Content, along with its associated Tool icons, and then copy/paste replace the entire modified code from Synthsin75's post into the copy.
Good luck!
tifacloud7
Greenlaw wrote: Sat May 24, 2025 8:57 am Hi,
Good luck!
Thank you so much, Greenlaw! I really appreciate your help.
I don’t have any coding background, but I’ll start by looking into Notepad++ and how to install it on a Mac.
That said, I’m still a bit confused about one thing…
Would you mind pointing me to where I can find the original script you mentioned? :oops:
Thanks again for taking the time to explain everything so clearly — it really means a lot!
Hi tifaclound7!
tifacloud7 wrote: Tue May 27, 2025 1:58 am I don’t have any coding background, but I’ll start by looking into Notepad++ and how to install it on a Mac.
Ah! Sorry, I should have asked which OS. Notepad++ is Windows only, but it's not required. I suggested it because it's free, but any Mac text editor should be able to edit a script.
Technically, you should be able to paste the code into an empty text file and save it to your Custom Content Folder with the correct filename. This is the reason I suggest copying the original file and modifying it, because it already has the correct filename. But you also need to include a copy of the button icons, which will be found in the same location as the original script.
I'm not sure where the original script file and button icon files are stored on Mac, but try poking around in the Moho application folder for them. If you're uncomfortable with that, I'm sure someone here will help shortly.
Besides the script and icon file location, everything I described should apply to Mac. If not, I'm sure someone will correct me on this.
Hope you sort this out soon!
tifacloud7
@Greenlaw
Thank you so much for your thoughtful reply.
I’ll give it another try — really appreciate your help again! :D
