LuaSocket
MehdiZangenehBar
LuaSocket
Post by MehdiZangenehBar »
Is it possible to add LuaSocket module to the Moho?
SimplSam
Re: LuaSocket
Post by SimplSam »
This is from a previous discussions:
I did find an out-of-the-box Windows binary 5.4 LuaSocket implementation that worked: https://github.com/alain-riedinger/luasocket. Release: https://github.com/alain-riedinger/luas ... /3.0-5.4.3
This just requires updates to path and cpath to point at the installed-to directory (scriptresources in my case), and then use.
    package.path = package.path .. ";" .. moho:UserAppDir() .. "/scripts/scriptresources/?.lua;"
    package.cpath = package.cpath .. ";" .. moho:UserAppDir() .. "/scripts/scriptresources/?.dll;"
Connection Test:
    local socket = require "socket"
    local connection = socket.tcp()
    connection:settimeout(1000)
    local result = connection:connect("ifconfig.co", 80)
    connection:close()
    print("result: ", result)
Simple HTTP Request *:
    local http = require("socket.http")
    local response = http.request("https://ifconfig.co/json")
    print("response: ", response)
* Note: There is a slight issue with this shipped LuaSockets build (which is 3 years old - and contains an old compatibility buglet) when using HTTP and Lua 5.3/5.4. (see: https://github.com/lunarmodules/luasocket/issues/331). The quick fix is to: Update/Replace all receive() calls in http.lua and tp.lua with receive("*l")
MehdiZangenehBar
Re: LuaSocket
Thank You Sam! I will check it out...
MehdiZangenehBar
Re: LuaSocket
Your solution works great!
My idea is to create an external app to cominucate with Moho using localhost, do you think it works?
MehdiZangenehBar
Re: LuaSocket
SimplSam wrote: Sun Apr 28, 2024 1:39 pm
Sam, would you please tell me where (in which file) , I can set those path and cpath settings?
Defims
Re: LuaSocket
Post by Defims »
SimplSam wrote: Sun Apr 28, 2024 1:39 pm This is from a previous discussions:
Connection Test:
    connection:close()
Thank you very much for sharing. :D I tested it on Windows and it worked successfully. However, on Mac, I referred to the Windows configuration to write the Makefile, and after compiling, I got the error 'dynamic libraries not enabled; check your Lua installation' when trying to call it.
error loading module 'socket.core' from file '/Users/xxx/moho/user_define_content/Moho Pro/Script/ScriptResources/socket/core.dylib': dynamic libraries not enabled; check your Lua installation
Through my search, I found a possible explanation: it seems the Mac version of Moho needs to be built with the “LUA_USE_DLOPEN” macro added during its compilation.
