CLI Rendereing in Moho 14.3?
caderial
Post by caderial »
viewtopic.php?t=1318&sid=34a67a710166dd ... 651bdb7a37
This FAQ is VERY old an dim wondering if 14.3 can do something like this? Also the -r use case could that be used to also run a lua script after opening a file?
none of this seems to apply anymore for 14.3? I would hope they'd expand upon this as they grew the software not rip this stuff out.
Form the FAQ section officially form Lost Marble:
-r filename.anme This is the only required command. It tells Anime Studio to render the given file and then quit. No GUI will be launched.
-v Runs the rendering job in "verbose" mode. In this mode, Anime Studio will print out messages about its status, including an estimate of the time remaining in the rendering job.
-q Runs the renderer in "quiet" mode. "quiet" mode disables all command-line output, both information and errors. "quiet" mode overrides "verbose" mode. This option was introduced in Anime Studio Pro 9.5.
-log logfile Specifies a log file for the render. Information and errors that are normally shown as command-line output are instead logged to the log file. This option was introduced in Anime Studio Pro 9.5.
-f format This tells Anime Studio what format to render the output as. Valid formats are QT (QuickTime - Windows and Mac only), JPEG, TGA, BMP, PNG, or SWF (Flash). The QT and SWF formats generate a single output file, while the other formats created numbered sequences of still images. If you don't specify a format, on Windows and Mac the default format is QT, on Linux the default is JPEG.
NOTE: Starting in Anime Studio Pro 9.5, the format type must be entered in lower case. Use jpeg instead of JPEG, png instead of PNG, etc.
-o outfile Specifies an output file. If you skip this option, the output file will have the same name as the input file, but with an extension matching the format you choose.
-outfolder folder Specifies an output folder for the render. The name of the output file will be named based on the file name of the document. For example, a document named MyAnimation.anme will create a movie in the output folder called MyAnimation.mov if the specified render format is QuickTime. Note that -outfolder folder overrides -o outfile. This option was introduced in Anime Studio Pro 9.5.
-start frame Specifies the starting frame to render. If omitted, Anime Studio will start rendering at the document's start frame (usually 1).
-end frame Specifies the last frame to render. If omitted, Anime Studio will render up through the last frame of the document.
Re: CLI Rendereing in Moho 14.3?
Command line rendering is still available. See appendix G in the user manual: https://manual.lostmarble.com/app/page/ ... gJw4U9flX3
I believe Moho would run any layerscripts during command line rendering, as these are primarily meant to run during rendering.
But since the command line render doesn't invoke the UI, I doubt any other scripts are evaluated. I haven't used this feature myself, so I'm sure others would know more.
