bone dynamics problems.
- hammerjammer
I'm so confused. I have used bone dynamics many times before, so its not a new concept to me.
HOWEVER, they no longer work in ANY file they are used in...
Older files, newer files and a test file I just created are not DOING ANYTHING. DEAD AND LIFELESS.
What in tarnation's is going on here? I'm I missing something? Did I forget to activate something? Did I turn something off by accident?
Its very frustrating. Any thought on what is happen would be GREATLY appreciated.
Hammerjammer
- hammerjammer
Re: bone dynamics problems.
Just for FUN and to try and see if I'm just crazy...
I created a test file in Moho 13.5 and saved it.
oped it in my moho 14.3 and it doesnt work... IM NOT CRAZY AFTERALL.
WHAT IS GOING ON HERE?
Hammerjammer
I just made a quick test in 14.3, and it works perfectly, have you tried to re-install Moho, as you seem to have quite a bit of issues?
https://www.youtube.com/watch?v=FAWuO-C3KK0
- hammerjammer
That idea has crossed my mind. I just cant find my Serial number.GCharb wrote: ↑Sun Jan 26, 2025 7:39 am I just made a quick test in 14.3, and it works perfectly, have you tried to re-install Moho, as you seem to have quite a bit of issues?
AND I'm not sure if that going to mess with my number of installs or not. I think maybe I'm supposed to deactivate it first.
I DONT KNOW
Hammerjammer
There is a show serial number function in the help menu, if you have a legit copy of Moho, your SN will show there!
- hammerjammer
Yes, Thank you. My copy is legit and I did find the S/N.
I uninstalled 14.3 then re-installed it fresh.
Bone dynamics is still not working. I'm at a loss for what to do now.
Thanks for the help though.
Hammerjammer
Do you have a simplified file (with only the necessary bones) you can post?
- hammerjammer
OK, I can post the Sample file I was playing with. Just for testing. Nothing fancy just a test.synthsin75 wrote: ↑Sun Jan 26, 2025 1:07 pm Do you have a simplified file (with only the necessary bones) you can post?
BUT I have no idea how to do that... Well maybe I do. Im assuming its thru some sort of file sharing app or something like that. What are most on here using as to avoid compatibility problems? I feel like such a rookie right now. LOL. The last time I did this was probably 14 years ago.
Hammerjammer
- hammerjammer
Wow, I found an OLD dropbox account that I had... The last time I post something on there was 14 years ago.
Anyway here is a dropbox link if that helps.https://www.dropbox.com/scl/fi/d6pr2c8h ... wvfx1&dl=0
Dont know if I did that right.
Hammerjammer
Is Animation > Enable Bone Dynamics switched on?
I know that sounds obvious, but I had to ask to be sure. If the option was switched off previously, it will stay off until it's switched on again...even after Moho is quit and relaunched.
- hammerjammer
YES its on. You can see it for yourself in the simple test file I uploaded here in the thread. Created in Moho 14.3, But its not working for me.
Hammerjammer
I just loaded that file and the carrot stem is wiggling just fine with no modifications to the file, so the problem is clearly on your end, I'd contact support if I were you, maybe they have a script or a more technical way to help pinpoint the problem!
The dynamic bone works here, in v14.3.
So the file itself is working. I can only guess that it's something with your install or computer. I don't know if an underpowered GPU could cause dynamics to not display.
Does rendering an animation show the dynamic?
- hammerjammer
I'm using the same PC that I have for a couple of years now. Everything worked before. I dont what changed. I thought that maybe there was something I turned off, but there is nothing to turn off. Other than the obvious, and it is ON.
Thanks for input. I hate this ghost in the machine type stuff.
I will figure it out sooner or later... I hope.
Hammerjammer
I doubt that it has to do with the system per se, Moho requirements are very low...
https://moho.lostmarble.com/pages/requirements
