Can Someone Explain this to Me?
Yosemite Sam
Post by Yosemite Sam »
I have a simple fire using particles. The problem is, once I move I go past frame zero, it doesn't work. it's like the main group is linked only to the mask at the bottom (which I turned on the path for the mask so it's easier to see. I thought maybe I had KFs before frame 0 but can't spot any. Could someone open this file and let me know if they can locate the issue?
Thanks
I added it twice because I'm still unsure which method works on this site.
https://www.dropbox.com/scl/fi/vqdqdc6b ... d65kn&dl=0
Jimmy Mills
Some of my Moho Pro work.
Re: Can Someone Explain this to Me?
Looks like it works fine here, in v14.3.
Will check it out in a bit.
Yosemite Sam wrote: Mon Jan 20, 2025 1:45 am I added it twice because I'm still unsure which method works on this site.
Both links take me to your Dropbox page. Then I can download from your page.
What I prefer to do is replace dl=0 at the end of the link with raw=1. This makes the link download the file immediately, without sending the user to an external DropBox page.
Yosemite Sam
synthsin75 wrote: Mon Jan 20, 2025 2:58 am Looks like it works fine here, in v14.3.
Thanks for checking, Wes
Jimmy Mills
Yosemite Sam
Greenlaw wrote: Mon Jan 20, 2025 4:10 am Will check it out in a bit.
Thanks for that Green!
Jimmy Mills
Yosemite Sam wrote: Mon Jan 20, 2025 1:45 am I have a simple fire using particles. ...
All fine here 14.3 Win 10.
What exactly is not working for you?
Yosemite Sam
Wes, this is what I'm seeing on my end.
https://youtu.be/vYcC17J2UaY?si=DklgqUBAKrgJR_XU
Jimmy Mills
Yosemite Sam
Green, this is what I'm seeing on my end.
Jimmy Mills
Yosemite Sam
hayasidist wrote: Mon Jan 20, 2025 11:53 am
This is what I'm seeing on my end.
Jimmy Mills
That's just a display update issue. If you scrub/play the timeline or render, it is correct.
Yosemite Sam wrote: Fri Jan 24, 2025 2:44 am This is what I'm seeing on my end.
<snip>
yeah - display issue - exactly as Wes says. The work area display isn't updated until you move away from the new key. Do the move as in your video. Then step one frame right and the flame re-appears.
Yosemite Sam
synthsin75 wrote: Fri Jan 24, 2025 3:05 am That's just a display update issue. If you scrub/play the timeline or render, it is correct.
Yeah you're right. Thanks!
Jimmy Mills
Yosemite Sam
hayasidist wrote: Fri Jan 24, 2025 8:24 am
<snip>
Thanks!
Jimmy Mills
