Guide for sound you will enjoy this :)
wildman1001
Post by wildman1001 »
kk are you sick of not having any sound programs that you have to gues were to put the sound in well then you troubles are over lol :) just follow these step by step instructions :).
kk first download flash player 8 and a avi to gif converter
now export your animation to an avi
convert that to a gif
then import it to library in flash
then right click on the list frame it is called what ever your animation is called
click on type and select graphic
simply drag the frame you have just changed into a graphic onto the page
then just change the frame rate to 24 or whatever frame rate you use
and resize the screen to whatever size you use.
now just insert a new layer and put your sound werever you like:) you will get it perfectly on time every time :) yay :)
and there you have it good luck :).
cribble
Post by cribble »
Very cool technique, but there's a different part of the forum where i think this should belong. Tips and Techniques. Post all your stuff there.
Wouldn't it be easier to export the timeline as png's or jpgs, rather than having to export to avi and then convert to gif and then import it. It seems a lot simpler just to export a sequence of images and import them straight into flash that way.
--Scott
cribble.net
wildman1001
thats were your wrong :) becoas that means you have to import the images 1 by 1 and with a gif it is allready put to gether and you only have to import one thing :D
