3D options dialog default settings.
- Bax Burgess
Any way to permanently change the defaults? So tired of setting them anew for every import.
Re: 3D options dialog default settings.
I hear you
Best idea I can think of is to save a project file with your settings the load it and change the object. I wish there were some more shape options in there as well. I'd be using the heck out of it if there were.
Cheers
D.K
Cheers
D.K
My store on Renderosity:
- hayasidist
should be scriptable -- in its simplest form a button to overwrite the default options with new (preset) values; in a more complex script - a replacement tool for the import menu option that creates a 3d layer from a user-selectable file that also allows load-time access to user-selectable default values for the 3d options such as backface removal etc etc
https://mohoscripting.com/classes/Mesh3DLayer
https://mohoscripting.com/classes/Mesh3DOptions
- Bax Burgess
A one-time preference setting would be the shortest of solutions, I'm guessing.
- hayasidist
it was pretty trivial to do ...
https://mohoscripts.com/script/HS_Set3dOpts
enjoy!
Any problems / issues just let me know.
enjoy!
- Bax Burgess
Thank you. I shall work with it later this evening, already installed.
Bax
Bax
