Continues drawing
Hamedss
Continues drawing
Post by Hamedss »
Hi.
If you check library - scenes - vp - ocac_ Camioneta
You will see very nice and funny scene.
There is a road with lines that morphing together and it confused me.
The animation is simple ,cycling and seamless.
What is the process to make that?
SimplSam
Re: Continues drawing
Post by SimplSam »
In terms of the 'continuous' effect. There is only one layer that mainly causes this, and that is 'lineas'.
If you look at or isolate that layer and step frame-to-frame you will see that it effectively moves the line markings along towards the next set of keyframes (@ frame 49) - where they perfectly match the position of where the next marking was, then cycles back to their original position - giving the illusion.
Alternatively - you can turn off that layer and notice how the other content just bobs around, not moving along.
Hamedss
Post by Hamedss »
Yes . That's it. I tried that and it worked. Thanks
