Hi.
Since version 14 of Moho, the tab no longer appear at the start despite the option in "View / Show Document Tabs" being checked.
If you want to close a current job to return to an old recording, the only way to reload the same file without having to restart the program is to uncheck then recheck the option so that the tab appear.
Bug with the "Show Document Tabs" menu
Re: Bug with the "Show Document Tabs" menu
You can use File > Close to close any document
You can also bring back the tab by - View > Show Document Tabs ... (twice) but I think you said that. Or opening a New / Other Doc
Thank you for this other workaround tip, but still it is a little bug (I think easily correctable) since the option is checked but does not appear at start, hence my report.
Yeah - I think that setting is a little misleading. Maybe it needs a setting like:
- On: Always On
- Auto: On for multi-docs / Off for Single
- Off: Always off
- On: Always On
- Off: Always off
- hayasidist
that issue was logged a while back ...
I forgot to specify that I'm on a PC (I don't know if this bug occurs on a Mac).
