No New layer Bug?
tinytaboo
No New layer Bug?
Post by tinytaboo »
Does anyone else have an issue where you can't create a new vector layer unless you restart the program?..
It will let me make one new one,.. then after that, the option is greyed out until I restart (as well as many other types of layers.
Thanks
Re: No New layer Bug?
If you're not on frame zero and have drawing tools enabled only for frame zero, it won't let you create new assets.
Borchc
Post by Borchc »
tinytaboo wrote: Sun Jun 02, 2024 4:32 pm Does anyone else have an issue where you can't create a new vector layer unless you restart the program?..
Thanks
Yes, it happens that the buttons in the layers window stop working, but the drop-down menu helps if you right-click on the layers.
It also happens that the actions window begins to behave in much the same way , this is already treated by closing and opening the actions window
tinytaboo
Post by tinytaboo »
synthsin75 wrote: Sun Jun 02, 2024 6:17 pm If you're not on frame zero and have drawing tools enabled only for frame zero, it won't let you create new assets.
Thank you so much! brilliant
tinytaboo
Post by tinytaboo »
Borchc wrote: Sun Jun 02, 2024 11:03 pm
Thanks
Thank you Borsch, helpful
