Frame by frame and Select Shape
Hubcube
Post by Hubcube »
Hello all,
It seems that I can only use the Select Shape tool once on a Frame by frame layer. If I select a shape and edit the style of that shape, I can no longer select another shape on another frame. I press the mouse button and it instantly abandons the selection upon release. I then have to re-open the project to be able to select a shape again. However, if I only select a shape without applying any modification, I can still select any shape I want. As if the selection was bound to one frame after playing with the style.
Anyone else observing this behaviour?
Thanks!
Moho Pro 14.1, Windows 11
Re: Frame by frame and Select Shape
I'm not seeing this. Latest Moho, also Windows 11.
Do you have an example file with this problem?
