Hi,
I use Moho 14.1, and when I create a "frame by frame" folder, I cannot see whats inside when you click on the triangle. I'm using Sonoma 14.2.1 on a Mac. I this a bug, or expected behaviour? In every video and older versions this worked.
Frame by Frame folder not showing frames
Re: Frame by Frame folder not showing frames
This is by design, apparently to make the frame by frame workflow less confusing.
If you need access to the sublayers, you'll need to convert the FBF layer into a switch layer.
Hi,
wow, thanks for the really quick response. This was faster as in some chats. Thank you.
