LK_Storyboard
Lukas
LK_Storyboard
Post by Lukas »
Useful in case you are using an image sequence as Storyboard, and if the Storyboard contains the shot layout as well.
You need a folder named "STB" in the same folder as the Moho file. (I suggest keeping each Shot in a seperate Shot folder, each with their own STB folder)
Inside the STB folder should be an image sequence.
Download link:
Re: LK_Storyboard
That's very cool Lukas! Will check it out.
Lae82
Re: LK_Storyboard
Post by Lae82 »
This is a very quick way to get rough drawings into moho for tracing. I prefer this method instead of having to create fbf layers and group etc and then import drawings. Would be nice if the storyboard folder + adding images could be created with a button inside of moho.
A good storyboard solution like this should come default with moho installation in the future.
Panha
Re: LK_Storyboard
Post by Panha »
Lukas wrote: ↑Fri May 26, 2023 2:13 am Download link:
Amazing. ❤️
lucasfranca
Re: LK_Storyboard
Post by lucasfranca »
Lukas, this tool of yours is incredible. Very functional!
But I would like to ask you something that in my opinion is very similar to what you did here. There is a way to integrate Cacani with Moho, which would be by exporting from Moho to Cacani in SVG (it would be cool here if a script created an artboard to use as a reference when importing again later), using Cacani to make traditional animations, export again from Cacani into an SVG image sequence and import into Moho. My question is: is there any way for a script to import this sequence of images in an FBF format?
Here's an article video about what I'm talking about (not mine):
https://youtube.com/animai2D
Lukas
Re: LK_Storyboard
Post by Lukas »
lucasfranca wrote: ↑Fri May 31, 2024 5:57 amBut I would like to ask you something that in my opinion is very similar to what you did here. There is a way to integrate Cacani with Moho, which would be by exporting from Moho to Cacani in SVG (it would be cool here if a script created an artboard to use as a reference when importing again later), using Cacani to make traditional animations, export again from Cacani into an SVG image sequence and import into Moho. My question is: is there any way for a script to import this sequence of images in an FBF format?
It's probably possible and might not even be that difficult (very different than this Storyboard script though), but my main machine is a Mac that doesn't run Cacani (also, don't own it), so I'd recommend trying to create a new topic in the Scripting forum with a request. The more info in the request explaining what you need to happen, the better :)
