pretty plzzzzz?
pretty pretty plzzzz?
RE: Destination folder option 4 batch render pleeaze?
- Lost Marble
anigreator
I'd like to see the batch renderer allow you to choose a folder for the output for each individual file. For example, I usually make my final renders to JPEG image sequences, then compile them together into a movie. If I'm rendering three different files, I want each sequence (of hundreds of images) to go into its own folder, so they are separate and easier to find and import into Quicktime (which is what i usually use to compile them). There could be a place in the project settings to specify an output folder, and this info would be saved with the Moho file as a setting. Then, when you put in your list for batch rendering, each file would go to it's specific location. It would make rendering multiple files much, much easier.
thanks,
Jack
thanks,
Jack
