PC version has lag when using "sticky key" feature
Fuzatron
Re: PC version has lag when using "sticky key" feature
Post by Fuzatron »
Awesome!
I hated to ask. If you find the time, it'd be much appreciated.. again :)
AH! thanks for this Wes - I noticed this problem but had no idea what it was :P
FYI, this is a quick way to add it to Win10 startup:
http://www.howtogeek.com/208224/how-to- ... ndows-8.1/
Fuzatron
Post by Fuzatron »
synthsin75 wrote:Here's the fix for Moho 12.
https://dl.dropboxusercontent.com/u/536 ... %20fix.zip
And all is right with the world again.... Well, at least with drawing in Moho anyway ;)
Big thanks again, Wes!
Nice tip, Funks :)
It was simple to update...no problem at all.
This problem from AS 11.2 is still an issue for 13.5 on Windows 10. Luckily, my above fix, updated for Moho 12, still works for 13.5.
mgo
Post by mgo »
Wes, thanks so much for the fix.
Always happy to help.
Oh, I wasn't aware of this fix! Thanks for posting the solution Wes.
I generally avoided using sticky keys in Moho because I thought the lag was normal when a Moho project reached a certain complexity or number of keyframes.
Will check my Repeat Rate to see how it makes a difference for a heavy project file, and then try the script to fix it specifically for Moho.
I took a few minutes to play around with this.
I checked my Repeat Rate and Repeat Delay setting and they were already set to the fastest/shortest settings.
For me the lag occurs most noticeably when the Style window is left open (as Wes noted,) even with a fairly simple project file. It's really bad with a more complicated project. When I close the Style window, Sticky Keys is reasonably speedy. Leaving the Tools or Switch Selection window open has a minimal lag effect...it's there but barely noticeable compared to when the Style window is open.
I guess this is fine for me because I normally keep my Style window closed during animation, but knowing specifically what causes the lag is very helpful!
Hopefully this lag with the Style window open gets properly fixed in a future update.
Fuzatoon
Post by Fuzatoon »
So the problem remains in 14 :!: but thankfully this fix still works 8)
Thanks again, Wes!
Fuzatoon wrote: ↑Sun Sep 17, 2023 3:25 pm So the problem remains in 14 :!: but thankfully this fix still works 8)
Thanks again, Wes!
Happy to hear the fix is still working.
