Locking Moho Objects/Laters
vivekchakraverty
Post by vivekchakraverty »
I know this may sound pretty rudimentary but how do you lock a moho scene object at a particular location?
Re: Locking Moho Objects/Laters
Can clarify what you mean by locking?
For animation, you can copy/paste a key to hold the position (my preferred method,) or you can use a Step key, which will hold the position until the next keyframe.
If you mean locking a layer so it can't be edited (like in After Effects,) unfortunately, Moho doesn't support that yet. In the meantime. I recommend installing Synthsin75's Lock Layer script. It's been very handy when I need it! :D
(Note: Link updated to preferred release. See below.)
vivekchakraverty
Non-bone, animated objects, I meant!
vivekchakraverty
Thanks a lolt, Greenlaw!
I wouldn't suggest using the one linked. Use this one instead: https://www.lostmarble.com/forum/viewto ... 36#p167236
vivekchakraverty
Thanks, :)
Thanks, Wes! I'm updating the link above and bookmarking it since I keep recommending your tool. :D
Greenlaw wrote: ↑Sat Sep 16, 2023 12:46 pm Thanks, Wes! I'm updating the link above and bookmarking it since I keep recommending your tool. :D
I just removed the link to the unstable version and replaced it with the good link, just in case anyone links to that post.
Maybe one day I'll figure out a better way to implement the non-button version.
