How to distinguish between points in Mesh animation?
NealF
Post by NealF »
Yikes. I've been at this for 2 days.
I just started to find out how to use the Mesh option to animate a graphic. I've got a baby who's moving his backside to the music.
He's standing with his back to us.
So I get the left side to move left and right at the correct rhythm. Then I try to move the right side left and right to make it look like one backside is moving together left and right.
When I try to get the right side to move in the right rhythm, there's no way to see which points are left and right. So I can't get the correct motion to the right side.
Am I doing this the wrong way? Should I be not using mesh for this? I'm not sure how to make it work with bones, if that's what I should be doing.
Thanks.
SimplSam
Re: How to distinguish between points in Mesh animation?
Post by SimplSam »
One thing you could do is use Hide Points. Go back to Frame 0, select just the Right-side butt points, then Edit > Select Inverse, then Draw > Hide Selected Points. Then go back to Frame X to animate the Right-side points. Finally - Draw > Show All Points to return to normal.
or create a point group for each side?
(in the select points tool - select the (say) left Points, type the name "Left" in the box and press the Create button. Repeat for the right side. )
NealF
Post by NealF »
Ah! That sounds so much simpler.
I'll give it a try asap. Still love the idea about the mesh. Must be some good uses for it. Just gets a bit complex.
Thanks.
NealF
Post by NealF »
Just realized there are no points in an image file.
The only way to get points is to make a mesh.
you can name the warp mesh points in the same way!
NealF
Post by NealF »
Do you know of any tutorials that tell you all about Groups and Shapes?
I'm still trying to figure those out.
