Can't install Moho 13.5 on M1 Macbook Air running Ventura 13.5
Pesto
Post by Pesto »
I have tried numerous times and I keep getting this error message. Does anyone know what is the problem?
Error message says:
A fatal error occurred loading application
Reinstall this application to correct the problem (Error - 7089)
Thanks
Re: Can't install Moho 13.5 on M1 Macbook Air running Ventura 13.5
Hello, Pesto. The -7089 error message typically means a Moho support file has gotten corrupted on your Mac (maybe you migrated your data from your old Mac to your new one, and the problem probably happened during that process). Make sure you've completely closed out of Moho, then delete this "Lost Marble" folder:
/Users/Shared/Library/Application Support/Lost Marble
Restart Moho and see if it works any better now.
Pesto
Post by Pesto »
Thank you for the help. Yes I did migrate from another Macbook. I did what you said and it installed perfectly and runs great. Thank you Victor!
Great. You are welcome :)
Erich Scheidle
Post by Erich Scheidle »
I tried it, but there is no Lost Marble folder on my Mac. What should I do?
Mikes1025
Post by Mikes1025 »
Víctor Paredes wrote: Mon Aug 07, 2023 7:21 am Hello, Pesto. The -7089 error message typically means a Moho support file has gotten corrupted on your Mac (maybe you migrated your data from your old Mac to your new one, and the problem probably happened during that process). Make sure you've completely closed out of Moho, then delete this "Lost Marble" folder:
This still works exactly as you said it. Thanks
