Hey!
Total Moho beginner here.
Is it possible for multiple shapes that share the same path to have different stroke exposures? Or are stroke exposure, line width, hide edge etc. tied to the path and not the shape?
And if it's not possible - is it possible to link two paths somehow? To make one path follow the shape of another via scripts?
I'm coming from after effects where i'm used to adding a ton of expressions inside shape layers to determine their shapes programmatically.
Thanks!
Toms
Multiple stroke exposures using one path
Re: Multiple stroke exposures using one path
Stroke exposure, line width, and hide edge are all path properties.
You can stack paths to make it look like there's more than one stroke exposure on one line. You can then weld the points alone the lines, so they animate as one.
If you do that, I would suggest making a layer with the paths unwelded and separated, in case you need to make changes, as the welded paths will be a bear to select. Then you can always make changes, stack, weld, and copy/paste them into the layer using them.
Hey! Thanks for the reply!
With the default tools I can only figure out how to weld points when I draw new paths.
Using the MR Curve script I can only weld the end points of a path.
Thanks!
Toms
Can you specify how you would weld the points on two existing paths?synthsin75 wrote: ↑Wed Jun 21, 2023 3:42 pm You can stack paths to make it look like there's more than one stroke exposure on one line. You can then weld the points alone the lines, so they animate as one.
Thanks!
Toms
- egypturnash
I'm coming from an Illustrator practice with a heavy reliance on complex Appearance stacks and trying to figure out how to do similar things. Making a Reference Layer and applying a different style to the shapes it clones from the original layer might be worth exploring, there's an example of this in the tutorial manual where it's used to create an outline above a masked eyeball object, and probably some discussions of it to be found if you search around here.
It feels like it might be more trouble than its worth unless someone's built a script to help speed it up, though.
(this is a suggestion from a fellow Moho novice so if one of the experts around here says this suggestion is a terrible idea, then listen to them.
old lady who might finally be recovering from having worked at Spumco at the turn of the century
