LoadDocument returns nil and not a MohoDoc
mminsel
Post by mminsel »
Hi,
I have the following issue:
When I run the following code:
print(moho.document:Path())
local newDocument = moho:LoadDocument("C:/path/to/file.moho")
print(tostring(newDocument))
I'll get the following printouts:
nil
Moho opened the document, but the moho object is now outdoated and in addition LoadDocument is not returning anything.
Actually I wanted to open a document, do stuff, save and close it again. But this doesn't seem to be possible.
Does anyone have had this issue before? Do you have an idea on how to work around this?
Re: LoadDocument returns nil and not a MohoDoc
if you have a new (unnamed) document as the active tab when you run the script, you'll get the empty string back.
also load returns a document object, so you'll need print(newDocument:Path()) not print(tostring(newDocument))
mminsel
Post by mminsel »
hayasidist wrote: ↑Fri Jun 16, 2023 2:15 am if you have a new (unnamed) document as the active tab when you run the script, you'll get the empty string back.
Hi hayasidist,
Thanks for your reply. The thing is, that LoadDocument returns nil and not a new document.
Which is why print(newDocument:Path()) will raise an error. The first empty string in my example code was expected, while the second empty string looks wrong to me.
do you actually have a file to load at the path you gave???
take a look at (e.g.) C:\Program Files\Moho\Resources\Support\Scripts\Tool\lm_scatterbrush.lua -- with focus on function LM_ScatterBrush:LoadDocument(moho, docPath) and the places from which it's called -- the script builds a string for the path and loads existing files with no problems.
SimplSam
Post by SimplSam »
As already stated the only place I have seen moho:LoadDocument being used is in the Scatter Brush tool (lm_scatterbrush.lua).
I have tried the function in a bit of code, and it seems to work/load OK.
local doc = moho:LoadDocument("W:/SqrCir.moho")
print(tostring(doc:Name()))
result: SqrCir
