Is there a way to close a SimpleDialog
mminsel
Post by mminsel »
Hi,
Is there a way to close a SimpleDialog, which was started with DoModal?
I've tried to call OnOK(), OnCancel() and EndDialog(dlg) but they were all undefined (nil).
I would like to close the modal dialog, after another button than the OK/Cancel button was clicked.
SimplSam
Re: Is there a way to close a SimpleDialog
Post by SimplSam »
To my knowledge the answer is no, but I wish the answer was yes.I would even like the option to close them from code in the main application.
mminsel
Post by mminsel »
Hi Sam,
That was my suspicion. I've now created a c++ lua module that allows to close the modal dialog using a workaround:
extern "C" __declspec(dllexport) int closeMenuWindow(lua_State * L)
	lua_lock(L);
	const char* windowName = luaL_checkstring(L, -1);
	lua_pushnil(L);
	lua_unlock(L);
#ifdef _WIN32
			std::thread([]() {
				std::this_thread::sleep_for(std::chrono::milliseconds(100));
				HWND hwnd = FindWindowA("LM_Wnd", windowName);
				if (!hwnd) {
					return 1;
				bool status = PostMessageA(hwnd, WM_KEYDOWN, VK_RETURN, 0);
				if (!status) {
					DWORD lastError = GetLastError();
					int i = 0;
				}).detach();
#endif
	return 1;
This needs to be done in a thread with a small delay, as the moho interface needs to have time to react, apparently.
SimplSam
Post by SimplSam »
That's a neat work-around. I also have an Elgato Stream Deck keypad which I use to initiate script and/or key-press sequences which are used to control some features of Moho.
bbrraayyaann
Post by bbrraayyaann »
mminsel wrote: Tue May 02, 2023 2:09 pm Hi,
To close a Domodal from another button you simply create a button in the dialog like this:
d.boton = LM.GUI.Button("Close dialog", LM.GUI.MSG_CANCEL)
l:AddChild(d.boton)
MehdiZangenehBar
Post by MehdiZangenehBar »
mminsel wrote: Fri May 05, 2023 3:02 am Hi Sam,
	lua_lock(L);
	lua_pushnil(L);
	lua_unlock(L);
#ifdef _WIN32
			std::thread([]() {
				if (!hwnd) {
					return 1;
				if (!status) {
					int i = 0;
				}).detach();
#endif
	return 1;
Any chance we can have access to that extension?
