export animation not working
charles-olivier
I can't export animation is it a limitation of the free version. the bottom ok is not active?
- hayasidist
Re: export animation not working
From the manual - Chapter 1 - in the section "demo limitations"
Demo Limitations
If you haven’t purchased a copy of Moho, then the program will be running in
demo mode. While in demo mode, Moho still allows you access to all features of the
program. Anything you can do in the full version you can do in the demo. Also, any
files you create with the demo version of Moho will still work fine if you purchase the
full version.
The demo version has just three limitations: First, you can only run the demo version
of Moho for 30 days. Second, you cannot import any external file formats including
images and movies. Third, you cannot export your animations to other formats
(QuickTime, AVI, Flash, etc.).
