Movements in wrap layer fails to 'translate' movements into image layer
Hugging_Bear
Post by Hugging_Bear »
Hi guys,
As you can see in this video, wrap and image layer got somehow disconnected. Does anyone knows how this happened (and to avoid this happening in the future)?
https://youtu.be/hY-2AFXIn3Q
The Guardian of Tales - YouTube Channel
https://www.youtube.com/@guardianoftales
Marik59
Re: Movements in wrap layer fails to 'translate' movements into image layer
Post by Marik59 »
I recently made a production and I also had this same problem. I have dropped the project for the moment until I find a solution.
My website here : AnnaTube
alanthebox
Post by alanthebox »
Hugging_Bear wrote: ↑Tue Dec 20, 2022 3:03 am Hi guys,
i admit i don't work with smart warps a lot, so, my tests might not match your workflow exactly, but i was able to recreate your issue on my first try. not sure how it got unlinked, but in my case, all i needed to do was go back into the layer settings for the image (in your case, "head - adult siegfried.png"), go to the image tab, and update the smart warp layer (in your case, "head - adult siegfried.png (warp)"). after that, everything worked as expected.
so, i guess my question is, have you opened up the layer settings and checked to see if the smart warp layer is still applied?
Hugging_Bear
alanthebox wrote: ↑Thu Dec 29, 2022 8:33 am
Thanks alanthebox for your tip. Next time, I'll know where to check and how to solve the problem. I assume it got disconnected because I moved the position of the smart bone dials in zero frame. With 'position' I mean the position of the base not the bone angle position.
