Fade In/Fade Out
thepunnery
Fade In/Fade Out
Post by thepunnery »
Hi. I'm trying to do a very simple fade in and fade out for a layer in Moho Debut. This was very very simple to do in Anime Studio, but apparently this involved scripts, which are only accommodated in Moho Pro. In lieu of that, I was trying to simulate a fade by going keyframe to keyframe and adjusting the opacity. Unfortunately changing the opacity for a given keyframe changes the opacity for that layer in the whole animation. Is there something I'm overlooking? Thanks!
Re: Fade In/Fade Out
You need to enable "Allow animated layer effects," in the layer settings, before you can animate layer opacity.
thepunnery
Thanks! That helps. Oddly, though, the fade-in effect shows up in the exported animation, but not when I cycle through the scene using the Play/Stop button. This is confusing and annoying. The layer in question happens to be a png file; could that be part of the problem?
You need to enable GPU acceleration in the display settings, to see opacity animation in the workspace.
