Pano Painter, an Interesting program.
Re: Pano Painter, an Interesting program.
Tried importing the test obj directly into Moho 13 this time. The materials do not automatically come into Moho with the object but it's easy to set up.
1. Import the obj. It will be added to a 3D layer.
2. Open the Material tab in the Layer Settings window for the 3D layer.
3. Select the material with the UV map (in this case, I had named it
Pano.)
4. With the Browse button, select the texture.
5. Click Apply. The texture should appear immediately.
6. Adjust the material settings to what you want. If you want the image to look exactly as painted, set Ambient Intensity to 100%. Set Diffuse Int and Specular Int to 0%.
As described before, you'll probably want to center the camera and scale up the sphere.
If you click and drag a corner of the 3D layer's transform widget, it should scale proportionately.
uncle808us
Post by uncle808us »
I wrote to him/her/ them at Pano Painter and within 2 hours they solved the problem.
Fastest response for software support in my memory. So back in business.
By the way Affinity Photo has the ability to do the same thing, paint pano from scratch or from imported panorama.
Later stay well everybody.
I started the distancing thing back when I hit 60 yro now I'm a hard core curmudgeon.
I use a MacBook Pro, and Anime Studio Pro 11.2
http://uncle808s.blogspot.com
Cool! Glad they got you up and running.
Re: Affinity, I didn't know it could do that. Photoshop CC has this feature too (3D > Spherical Panorama,) which is what I use at my work to paint/edit panoramic images. I guess this is more common than I thought.
But Pano Painter is much more affordable and I like supporting and promoting indie developers with good ideas. Will continue to play around with it and when I'm more comfortable with using Pano Painter, maybe I'll record a how-to video. :)
uncle808us wrote: Sat Apr 11, 2020 10:26 am I started the distancing thing back when I hit 60 yro now I'm a hard core curmudgeon.
Ha, ha! I'm not 60 but I think I'm following that same trajectory. (I'm grumpier in person.) :)
eric1223
Post by eric1223 »
Greenlaw wrote: Sat Apr 11, 2020 8:52 am ....
Unless I'm missing something, it seems to only export JPEG, which isn't great. But for $2, I really shouldn't complain...plus it is fun to play around in.
It Exports as PNG too.
1.Go to file And find "Export JPG"
2.Click Arrow Next to it, and Click PNG
Cool!
Thanks. I thought it was odd that I only saw JPG but glad to see there are actually several formats under the arrow.
Spherical maps work in Moho since v9. I did some tests drawn in TVPaint:
SuadAnny
Post by SuadAnny »
The styles are all pretty similar there
