Fatal Error 7089
onurdemirsoy
Fatal Error 7089
Post by onurdemirsoy »
Hello everyone,
My pc freezed while working and I restarted it now I can't open Moho. It gives me a fatar error -7089
I deleted and reinstalled it. Nothing changed. Also deleted Lost Marble folder but it still gives me this error. How can I fix this? Thank you
Re: Fatal Error 7089
Hello, Onur
That error message typically means a support file has gotten corrupted. Make sure you've completely closed out of Moho, then delete this "Lost Marble" folder:
/Users/Shared/Library/Application Support/Lost Marble
Restart Moho and see if it works any better now.
I hope this helps!
onurdemirsoy
Hello Victor
I am using Windows 10 and I deleted AppData\Roaming\Lost Marble folder but it didnt work. Should I delete another folder?
onurdemirsoy
By the way I changed the user and tried to reinstall it but still the same error
onurdemirsoy
I solved the issue.
I deleted the Lost Marble folder in C://ProgramData folder
Everything works nice now. Thank you Victor.
SimplSam
Post by SimplSam »
Other similar problems have required deletion from: C:\ProgramData\Lost Marble
Some people also had to remove "Smith Micro" folders.
** hehe ** I must be getting slow at typing !!
onurdemirsoy
I happily don't have Smith Micro folder anymore :)
Sorry, Onur, I was looking for another solution, but I'm happy you could solve it already.
onurdemirsoy
No problem it is solved. Have a nice day.
Erich Scheidle
Post by Erich Scheidle »
It does not work on my Mac, since I do not have a Lost Marble folder.
