Moho Layer Sequencer tool
SimplSam
Post by SimplSam »
A simple Moho tool script to view & adjust a sequence offset position in the timeline.
Notes:
Any changes made are dynamic and in real-time, so you will be able to see the effect of those changes in the timeline & viewport. Use the Cancel button to UNDO any changes. OK will confirm them. Reset to zero the layers' offset.
You can either set the relative Layer Offset -or- absolute Layer Start Frame, and the other value will be adjusted accordingly. The relative offset is calculated relative to the Document start frame, plus any additional offset already present in the layers' parent group/s.
Features:
  • Show current Offsets
  • Allow numerical entries
  • Use Relative or Absolute frame referencing
  • Dynamic real-time updates - allowing you to see the effects of changes in the timeline and viewport
  • Nudge Left / Right click-buttons
  • Increase/decrease values & position with mouse scroll wheel
  • Indicates offset inherited from Parent groups
  • Reset to zero offset
  • Cancel to undo changes
Available at:
- http://mohoscripts.com/script/ss_sequencer
- https://github.com/SimplSam/moho-sequen ... master.zip
Re: Moho Sequencer tool
hey -- thanks for this -- I might just start making more use of the sequencer now ...
alanthebox
Post by alanthebox »
I've already started using this tool on a crowd scene. It's been great to duplicate characters and offset them without having to scroll through hundreds of layers in the sequencer! thank you!
chucky
Re: Moho Layer Sequencer tool
Post by chucky »
Great script Sam, works really well, especially useful so far for audio and video, cueing up animatics and dialogue has never been so easy.
viccho
Post by viccho »
Hi
i'm sorry, but i do not know how to launch the script. I think i've well install it (in the right content folder), but i can't see it on the sccript menu. i'm on the sequencer view. do i have miss something
SimplSam
Post by SimplSam »
viccho wrote: Wed Sep 07, 2022 5:11 am Hi
If it is installed correctly - then there will be a new Icon in the Tools palette (on the left) in the "Other" section:
Click the tool button.
