*UPDATED 3/1/19* Layer Shortcuts tool
Re: *UPDATED 3/1/19* Layer Shortcuts tool
Ha, ha...brilliant! Thanks for sharing the idea. I can see myself possibly using that.
BTW, for the time being, I stopped using Layer Shortcuts, and went back to using Alt + R-click to select layers in the Workspace.
Unfortunately, this method doesn't work so well for Switch Layers when the Switch Layer contains groups, even with Alt + Shift + R-click to select the parent group because the Switch layer is next group layer above that.
One thing I really liked about about using Layer Shortcuts was that I could easily and reliably select any Switch Layer and have it load into the Switch Selection window.
I haven't given up on Layer Shortcuts though...looking forward to the fix!
I have installed the v2.6 on Moho 14.1 MacOS. There are no available shortcuts in the dropdown and the "assign" is always in gray.synthsin75 wrote: ↑Mon Jan 21, 2019 11:35 am This is a major update to a quick tool I wrote for a request Victor made here: http://www.lostmarble.com/forum/viewtop ... 51#p186251
This update is the same link: https://drive.google.com/uc?export=down ... yf2lql7JMx
Latest version: 2.6
With this tool selected you can assign keyboard shortcuts to instantly select specific layers. [[I've disabled keyboard shortcuts for now. This avoids errors in v13.5, until I can fix them. Workspace buttons will work without any errors.]]
Is the keyboard shortcut still disabled by now?
Thanks.
There are no plans to reintroduce that feature in the foreseeable future.
