Hi,
I can't seem to delete bones? I select the bone I want to delete, but neither the delete nor the backspace key do anything.
Using Moho 13.5.5 on OS X
Cheers, Daan
Can't delete bones
Daan Muller
- hayasidist
Re: Can't delete bones
which tool and layer have you got selected? You need the bone layer active and one of the bone tools (but not manipulate) selected before the bone can be deleted.
Daan Muller
Working now after starting Moho again. Thanks!
You also need to be on Frame 0 - which may have been the issue.
- hayasidist
only if you have "enable drawing tools on frame 0" set (I can delete bones away from frame 0 here if that's not set...) That "frame 0" option seemed redundant now that drawing tools draw "on 0" wherever they are invoked - but this has just added a new reason maybe to keep it?!
