LK_ShyPoints - Set points to shy and toggle show/hide shy points
Like shy bones, this let's you do the same with points.
Here's the download link:
Use my included custom Select Points tool to set bones to shy. Use the show/hide bones tool to toggle their visibility. I've got the keyboard shortcut set to <shift> + <B> to toggle shy points and <cmd/ctrl> + <B> to toggle shy bones (the latter might be default).
My select points tool has some really useful other features too.
edit: newer version are here:
- davoodice2
Re: LK_ShyPoints - Set points to shy and toggle show/hide shy points
fantastic!Lukas wrote: ↑Mon Oct 04, 2021 9:25 am Like shy bones, this let's you do the same with points.
thanks for sharing.
Hello Lukas,
Thank you for posting these amazing scripts. I really love them. I installed your latest script but I constantly get this message:
[url]https://www.mediafire.com/file/d9awtjk6 ... 2.png/file[/url]
Any help?
Any help?
I've updated the .zip. The error should be gone now.
Edit: Just a second, the upload failed
Edit: Should be online now
Hello Lukas,
thank you very much for this Select-Points tweak.
I'm currently assembling my first tool-set and your scripts are amazingly handy to use.
I'm using Moho 13.5.5 (x64), the zip-file from your post (SelectPoints Version 6.1) and have three things to point out (pun not intended):
1. the button for shy points currently displays "Shy bone" (really sorry for being so picky
2. the button "Slink points horizontally" does the same as the "Slink points both horizontally and vertically" button
3. currently the option to toggle lasso mode through Ctrl seems brocken or maybe not completely implemented yet? When I hold the button and click i get a nil value exception for index field lassoList at 381 and don't know how to fix it. (again sorry, just started the ride into the wild world of Lua
Greetings Alex
Greetings Alex
I updated the first post with new url's for updated versions of the scripts. I think these issues are already solved in those versions. Let me know if there's still any issues with them.AlexH wrote: ↑Fri Jun 03, 2022 3:40 pm Hello Lukas,
thank you very much for this Select-Points tweak.I'm currently assembling my first tool-set and your scripts are amazingly handy to use.
1. the button for shy points currently displays "Shy bone" (really sorry for being so picky)
3. currently the option to toggle lasso mode through Ctrl seems brocken or maybe not completely implemented yet? When I hold the button and click i get a nil value exception for index field lassoList at 381 and don't know how to fix it. (again sorry, just started the ride into the wild world of Lua)
Greetings Alex
Thank you Lukas and what a coincidence! I'm really sorry. I missed that you just updated your tools at mohoscripts.com one day ago (I will check out the other ones for sure!
The only remaining issue for the Select-Points-Tool I recognized at the moment is the nil value exception for index field lassoList (now at line 422) while holding Ctrl.
And maybe my screen resolution is too low, because the menu buttons couldn't be displayed completely and overlap the "Library" button, but I intend to fix that by shortening some button names.
I tried the Curvature- and Transform-Points-Tools too. The Lock Curvature feature is really neat! I can imagine some situations where this could be really a blessing in the skys.
Unfortunately now I have the issue that, if I create a point group (e.g. through setting their color with Select-Color) and enable "Show Bezier Handles" in the Curvature-tool, the beziere handles and points are displaced with a strange offset.
Same goes for the Transform-Points-Tool, but for every point, not just the ones within point groups, but this could be also a nice feature in case, someone would like to seperate the handles to get just the artwork.
Thanks, I fixed it for LK_Curvature, the new version is uploaded here https://mohoscripts.com/script/LK_CurvatureAlexH wrote: ↑Sun Jun 05, 2022 6:32 am I tried the Curvature- and Transform-Points-Tools too. The Lock Curvature feature is really neat! I can imagine some situations where this could be really a blessing in the skys.
Same goes for the Transform-Points-Tool, but for every point, not just the ones within point groups, but this could be also a nice feature in case, someone would like to seperate the handles to get just the artwork.![]()
Will update and fix LK_TransformPoints soon too.
(edit: Fixed and updated LK_TransformPoints too)
(edit2: Scrap that, don't use LK_TransformPoints at all, delete it and update LK_Curvature, the latest version works with the original transform points tool because it overrules the viewport code of LM_TransformPoints)
I added an option to hold <shift> to constrain handle direction. Get v2.4 here: https://mohoscripts.com/script/LK_Curvature
Thank you again for keeping up.
I'm sorry to tell you that by holding Shift while dragging a handle I get the nil-value-exception "attempt to call method 'NearestPointOnLine' " (line 281).
But neverless the overruled Transform-Points-Tool works just fine and is a great idea in my opinion.
Also I would like to recommend you to currently remove your Transform-Points-Tool from the Select-Points ZIP and Optional-Section on MohoScripts, to prevent other users from using it in the current state.
https://mohoscripts.com/script/LK_SelectPoints
I'm looking forward to the Curvature-Tool with constrained Handles and Select-Points-Tool with Lasso-Toggle-Shortcut, but take your time.
No problem, it's very useful for our production too, so I appreciate the bug tracking.
Sounds like you have an old version of FO_Utilities.lua installed. Try updating and see if that fixes it.
Nice catch, I thought I removed it everywhere. Should be gone now.
You were right. Everything is safe and sound now.Sounds like you have an old version of FO_Utilities.lua installed. Try updating and see if that fixes it.
