No AA Dotted Lines When Below 2.0 Width Causes Heartache and Despair Moho Pro 14
BigBoiiiJones
Post by BigBoiiiJones »
So I always tend to export my stuff with no AA its kind of the standard when animating in Japanese anime media due to external AE plugins like OLM and PSOFT that are common mainstream tools used in the anime industry and most of those plugins don't work when AA is preapplied. So my issue is when doing work for other companies or my own stuff and I use a line width that is lower than 2.0 I get dotted artifiacts. I don't get this issue in other software like Clip Studio, RETAS, CACANi, or OpenToonz and I doubt the render engine is supposed to handle smaller line widths this way so I'm reporting it here. Not sure if anyone else has this issue but its definitely a problem that is consistently repeated on my end. This also happens when using the line width tool to set a lower line width.
m upload
Last edited by BigBoiiiJones on Wed Oct 11, 2023 8:39 am, edited 2 times in total.
Re: No AA Dotted Lines When Below 2.0 Width Causes Heartache and Despair Moho Pro 13.5.2
Here's what I believe is going on...
In Moho a 1 pixel wide stroke is literally 1 pixel wide at your current project size. In other words, a 1 pixel wide horizontal line will take up exactly 1 pixel in height of your frame. If you set your stroke to 0.5 pixel wide and draw a line say 25 degrees, and you have AA disabled, you will probably get a broken line because It's not possible possible to draw line thinner than a pixel and Moho is averaging where it should draw a full size pixel. Depending on the angle of the stroke, this line might appear more broken or less broken.
When you have anti-aliasing enabled and you set a thinner than 1 pixel stroke width, I think Moho is then able to simulate a thinner line by blurring the pixels...so this is a visual trick and the stroke is not actually drawn thinner. Zooming in on the line should reveal this. I'm sure this is true for other programs too when drawing the lines under the same condition.
To check this, set your project size to 8 x 8 pixels, and then set your stroke to 1 wide pixel and draw a horizontal line...the line will take up 1/8 your canvas. But if you set the stroke to 0.5, the line will still only take up 1/8 of your canvas. (Note: I suggested 8 x 8 pixels because Moho doesn't allow a smaller canvas size.)
If you're intention is to use OLM in Ae, I would avoid using a stroke thinner than 1 pixel in Moho. At full HD res, a 1 pixel wide stroke is pretty darn thin anyway.
I just checked this in Clip Studio and, yes, the program is faking the thickness of lines thinner than 1 pixel.
For example a 0.5 pixel wide black line with AA disabled looks exactly the same as a 1.0 pixel wide line with AA disabled. When you enable AA, the 0.5 pixel line may look thinner than the 1.0 pixel line but the AA is just blurring the line, making it look gray instead of black...the result can appear to be a thinner line but it's really a blurry gray line...just like what you get in Moho with AA enabled.
BigBoiiiJones
Greenlaw wrote: ↑Wed Mar 16, 2022 12:05 am I just checked this in Clip Studio and, yes, the program is faking the thickness of lines thinner than 1 pixel.
I could understand the anything under 1.0 I just researched myself and this is actually a surprise to me tbh. Never noticed it. However the problem is Moho does this for lines under 2 a lot of anime work is usually done between 1 to 6 in pen pressure. It's a issue on how Moho distributes the no AA with lines from 1.0 to 1.9
Edit: Just to make things clear this image is from Clip Studio
Oh, shoot...you're absolutely right.
I recreated those lines from your image and I see what you mean. With AA enabled all three lines look fine but when disabled the only unbroken line I'm seeing is the 2.0 one. So Moho strokes below 2.0 are not usable for OLM in Ae.
I guess I hadn't noticed because I often render with AA enabled, and when I need to render with no AA to use OLM in Ae, I typically use 2.0 or thicker strokes. Hmm.
I'll try to point the devs to this thread and see what they think. :?
I tried this same test in Clip Studio Paint using the vector pen tool with AA disabled and I see no broken lines there.
It also seems like the line weights with AA disabled are more accurately represented in CSP, that is CSP's 2.0 non-AA line is clearly heavier than Moho's 2.0 non-AA line. Maybe Moho is not drawing strokes with the proper weight when AA is disabled?
BigBoiiiJones
Just want to say this issue is still happening with 13.5.5 So I'm updating the topic title to newer version
BigBoiiiJones
Re: No AA Dotted Lines When Below 2.0 Width Causes Heartache and Despair Moho Pro 13.5.5
Just bumping since this is a issue in v14 still.
BigBoiiiJones
Re: No AA Dotted Lines When Below 2.0 Width Causes Heartache and Despair Moho Pro 14
Still a issue in 14.1
BigBoiiiJones
Still a issue in 14.2 kind of disappointed since they seemed to update AA for masking so there was some small hope for no AA improvements but still no improvements to be found on this issue. Hopefully this could be looked into the next iteration of 14 or even version 15....
BigBoiiiJones
It's still a issue in 14.3 and even worse somehow. There is more separation within the lines and if you do a straight line there is big gaps along the vector paths making it look as if you used the hide edge tool in some areas. I really wish Moho would fix the non-aliased version of their lines.
Yeah, it's a problem. I, too, sometimes need to render from 2D animation programs without AA enabled so, in compositing, I can apply effects to the footage more cleanly and precisely and then apply AA as a post-process. This issue breaks this workflow option.
I probably hadn't noticed it before you brought it up here because I often render with heavier linework, but I know it will come up for me eventually.
BigBoiiiJones
Still an issue in 14.4 no improvements at all. It’s honestly disappointing and quite surprising, especially given how much Moho has been marketing toward the Japanese audience lately. It’s baffling that such a issue for Japanese workflows continues to be overlooked.
So many productions in Japan need to render without AA to make compositing easier or to allow for clean fills when coloring outside of Moho in programs like PaintMan or CSP. Even most indie creators in Japan follow this approach it’s simply the industry standard here.
I’m really disappointed this hasn’t been addressed yet, and I sincerely hope it gets fixed soon. This is a serious issue that affects a lot of professional workflows.
On this issue, I agree. When I was with DreamWorks, I was occasionally asked to fix animations from partner studios overseas, and I would receive rendered frames with no antialiasing. This made the footage much easier to work with in compositing (using OLM Tools.)
I hope to see improvements to line quality in a future version, but I imagine this requires significant work, and it probably won't happen in the 14.x cycle. (Maybe 15? Wishful thinking, but fingers crossed.)
Even so, Moho 14.4 is still a pretty awesome update! :D
