MR Overlay 2
MR Overlay 2
The videos are in Russian but English subtitles are available.
Script allows you to create an “overlay” - a new layer that can be used as a visual reference.
The content of the layer is based on the selected points or vector layers.
You can choose the color and line width, turn off the fills and mirror the overlay.
MR Overlay 2
https://mohoscripts.com/script/mr_overlay
MR Overlay 2
Re: MR Overlay
This looks fantastic! I will look for the time to test it myself.
Thank you very much for sharing it and for the very clear tutorial.
Re: MR Overlay
Thank you so much!
Re: MR Overlay
Thank you!
Re: MR Overlay
Thanks again KuzKuz for your great scripts!!!!
All the best for the season and new year!
Cheers
D.K
Cheers
D.K
My store on Renderosity:
Re: MR Overlay
Version 1.1 is available - https://mohoscripts.com/script/mr_overlay
1. New option 'Visible Layers Only'.
2. New option ''Preserve Strokes Alpha". This can help if you only want to change the color of the strokes without affecting the transparency.
3. Improved results with animated shape order, animated colors, and strokes width.
Re: MR Overlay
Oh, geez! I've wanted something like this for a looong time but somehow I missed MR_Overlay when it was released last winter.
Thanks for creating and sharing another incredibly useful tool KuzKuz.
Downloading now!
Downloading now!
Re: MR Overlay
Great, I hope the script will be useful for you.
Re: MR Overlay
Bug fixes:
1. Now the script should work in Moho 12 again
2. Fixed position of Bezier handles on overlay
3. Fixed an error related to missing shapes.
Download link - https://mohoscripts.com/script/mr_overlay
Re: MR Overlay 1.2
The script has been updated to version 1.2 to work correctly with MR Path.
Re: MR Overlay 1.2
Doesn't work for complex models. Is this my setup issue?
https://www.dropbox.com/scl/fi/wv7b08p4 ... bltrd&dl=0
moho14 script1.3
moho14 script1.3
Re: MR Overlay 1.2
Thank you, I've fixed the 'Out of range' error.mohgirl wrote: ↑Mon Sep 18, 2023 6:14 pm Doesn't work for complex models. Is this my setup issue?
moho14 script1.3
However, the other issue is not an error. You have the "Auto Select Points" option turned off, so the Overlay is created only for curves that have selected points.
Turn on the option for the Overlay to be created for the entire model.
Re: MR Overlay 1.2
Thank youKuzKuz wrote: ↑Tue Sep 19, 2023 1:42 amThank you, I've fixed the 'Out of range' error.mohgirl wrote: ↑Mon Sep 18, 2023 6:14 pm Doesn't work for complex models. Is this my setup issue?
moho14 script1.3
