smart bone problems
mohgirl
smart bone problems
Post by mohgirl »
The character's body gets messed up when I create the Smart Bones, I haven't figured out why?
Below is the project file
Software version 13.5.4
System win10
https://www.dropbox.com/s/ciw6bx5vw2744 ... e.rar?dl=0
Re: smart bone problems
there are many keyframes in the negative part of the timeline (not sure why this happens). use Wes's tool to delete them: https://lostmarble.com/forum/viewtopic. ... 98#p194298
B21 is parented to the head bone (B4) - delete the link?
That should fix at least some of the problems.
Let me know how you get on!
Hello. I checked the file and the issue is it has negative frames.
This is a tricky one and I'm still not sure about how this happens, but at least Wes wrote a script that quickly solves the issue.
Simply install this script in your Custom Content folder and then run it on your file:
https://lostmarble.com/forum/viewtopic.php?t=32714
(sorry, crossed posts)
Víctor Paredes wrote: Fri Apr 29, 2022 2:36 am Hello. I checked the file and the issue is it has negative frames.
The file looks as though it was initially created with an older version of Moho back in July 2018 -- so those negative keys could have been around for some time!
mohgirl
Post by mohgirl »
hayasidist wrote: Fri Apr 29, 2022 3:10 am
Yes, this problem has bothered me for a long time. This character evolved from the old model. Of course, the problem also came with it
