Someone please help me to modify this script.
bbrraayyaann
Post by bbrraayyaann »
Hi, I recently downloaded this script from this site:
https://mohoscripts.com/script/sz_recolor_layer
It is an excellent script, I use it mainly to paint many vectors or shapes at once.
But I would also like to be able to paint 3d shapes in the folder, for example I want to paint all vectors and in a folder there are also 3d files and I would like it to paint them.
Please is there someone who can modify it?
I tried to do it but I am very inexperienced.
Re: Someone please help me to modify this script.
same as before about "fill" and "stroke" - it's to do with the material of each face. http://www.lostmarble.com/forum/viewtopic.php?p=201756
and localisation as here: http://www.lostmarble.com/forum/viewtop ... 32#p193632
also, 3d materials are not animatable (so the stuff in Stan's script about keyframes is not relevant to 3d)
hope that moves you forwards!
bbrraayyaann
Hi, I am trying to do something like this:
but I get stuck what method or function can I use to paint the 3d and 2d shape?
ScriptName = "Pintar"
Pintar = {}
function Pintar:Name()
	return self:Localize('UILabel')
end
function Pintar:Version()
	return '1.0'
end
function Pintar:UILabel()
end
function Pintar:Creator()
	return 'brayanmartin'
end
function Pintar:Description()
	return self:Localize('Description')
end
function Pintar:ColorizeIcon()
	return true
end
-- Is Relevant / Is Enabled
function Pintar:IsRelevant(moho)
	return true
end
function Pintar:IsEnabled(moho)
	return true
end
-- Keyboard/Mouse Control
function Pintar:OnMouseDown(moho, mouseEvent)
end
function Pintar:OnMouseMoved(moho, mouseEvent)
end
function Pintar:OnMouseUp(moho, mouseEvent)
end
function Pintar:OnKeyDown(moho, keyEvent)
end
function Pintar:OnKeyUp(moho, keyEvent)
end
-- Tool Panel Layout
Pintar.BOTON_PINTAR = MOHO.MSG_BASE
function Pintar:DoLayout(moho, layout)
	self.vamos_a_pintar=LM.GUI.ColorSwatch(true)
	self.boton_pintarButton = LM.GUI.Button(self:Localize('Boton_pintar'), self.BOTON_PINTAR)
	layout:AddChild(self.boton_pintarButton, LM.GUI.ALIGN_LEFT, 0)
	layout:AddChild(self.vamos_a_pintar , LM.GUI.ALIGN_LEFT, 0)
end
Elegir={}
function Elegir:Es_vector_3d(moho,layer)
	local layerCount
	local i
	layerCount = layer:CountLayers()
	if ( layerCount == 0 ) then
		return
	end
	for i=0,layerCount-1 do
		local childLayer =layer:Layer(i)
		local childLayerType = childLayer:LayerType()
		if ( childLayer:IsBoneType() ) then
			Elegir:Es_vector_3d(moho,moho:LayerAsGroup(childLayer))
		else
			if ( childLayerType == MOHO.LT_3D ) then
				---I want to paint here I have already found 3d
			elseif ( childLayerType == MOHO.LT_VECTOR ) then
				---I want to paint here I already found the vector form
				local mesh = layer:Mesh()
				for i = 0, mesh:CountShapes() - 1 do
        			local shape = mesh:Shape(i)
        			shape.fMyStyle.fFillCol:SetValue(0,true)
function Pintar:HandleMessage(moho, view, msg)
	if msg == self.BOTON_PINTAR then
		print("When you click on paint all shapes will be painted including 3d")
	else
	end
end
-- Localization
function Pintar:Localize(text)
	local phrase = {}
	phrase['Description'] = ''
	phrase['UILabel'] = 'etiqueta_pintar'
	phrase['Boton_pintar'] = 'Boton_pintar'
	local fileWord = MOHO.Localize("/Menus/File/File=File")
	if fileWord == "Файл" then
	end
	return phrase[text]
end
2d shape -- see Stan's tool .. that's a great start.
3d shape: this needs a "material" to be defined.
You have some options:
1: present the list of materials already defined and allow the user to select one or to define a new one.
2: just define a new one (and ignore the fact it might be a duplicate)
(see http://www.lostmarble.com/forum/viewtop ... 94#p201794 and https://mohoscripting.com/classes/M_Mesh3D)
then, for the selected layer, change the material for each of the faces to be the selected / created one - call it material #m
	for i = 0, mesh:CountFaces()-1 do
		local face = mesh:Face(i)
		face.matID = m
	end
As previously noted, Moho doesn't have any UI for selecting points / faces in a 3d mesh, so you're really in an "all or nothing" situation (unless you want to try to build a picker!?)
(see http://www.lostmarble.com/forum/viewtop ... 56#p201756 and https://mohoscripting.com/classes/M_Face3D)
bbrraayyaann
hayasidist wrote: ↑Tue Mar 22, 2022 11:35 am 2d shape -- see Stan's tool .. that's a great start.
Hello, thank you for replying.
Here is the tool, it's a test I'm doing - I first try to paint the vectors of a group.
first I try to paint the vectors of a group.
but it gives me error (MESH A NIL VALUE)
What I want to achieve is to paint all the vectors and 3d objects of a group to the same color.
Here is the proof: https://www.mediafire.com/file/d9dgswq1 ... l.zip/file
take a look at the "common problems" section on https://mohoscripting.com/
you need to add a line childLayer = moho:LayerAsVector(childLayer) (see https://mohoscripting.com/methods/68) before trying to access the (2d) mesh.
bbrraayyaann
hayasidist wrote: ↑Tue Mar 22, 2022 2:04 pm take a look at the "common problems" section on https://mohoscripting.com/
Thank you, this is getting complicated for me.
Now I need to set the color to the shape.
But I will investigate
Stan's script is a good model to follow ... note that he has separated the UI from the actual "loop through the layers and change things" processing.
IOW the bulk of his SZ_RecolorLayer:Run(moho) happens only after the user commits the requested changes (presses "OK") and then it scans for layers to change (self:ScanLayers(moho) ) which fills in a table; and this table is then used to drive the loop to recolour (for [all table entries] do; self:RecolorLayer(moho,l,f); end )
bbrraayyaann
hayasidist wrote: ↑Wed Mar 23, 2022 3:48 am Stan's script is a good model to follow ... note that he has separated the UI from the actual "loop through the layers and change things" processing.
Hi Hayasidist, I solved the problem, I can now paint the vectors.
Now I get this error . Mesh 3d (NIL VALUE).
When I want to paint the 3d object.
Archive : https://www.mediafire.com/file/nrd3uset ... t.zip/file
Take a look back at my previous reply to you, and the linked pages: http://www.lostmarble.com/forum/viewtop ... 22#p203622 for recolouring 3d objects
mesh3d does not have shapes - it has faces.
so your code
				for i=0,mesh3d:CountShapes()-1 do
					local shape3d=mesh3d:Shape(i)
					shape3d.fMyStyle.fFillCol:SetValue(moho.layerFrame,self.vamos_a_pintar:Value())
won't do anything except cause Lua to cough up errors.
What you need to do is
-- choose or define a material
-- assign that material to each face in the 3d mesh
bbrraayyaann
hayasidist wrote: ↑Wed Mar 23, 2022 5:08 am Take a look back at my previous reply to you, and the linked pages: http://www.lostmarble.com/forum/viewtop ... 22#p203622 for recolouring 3d objects
But if you look at the file I sent you,
if you go to the 3d object and select : Style, advanced, shapes.
There is a shape (MAT) that can be colored as if it were a vector.
bbrraayyaann
I'll try what you sent me and let you know what happens, thanks
