I've been getting errors trying to download this ... "download1334.mediafire.com is not responding" ... tried over the last 3 or so hours - same issue each time.. obviously others are not seeing this - wondering if it's an issue with US-UK traffic?? (my own mediafire account is working ok!) Any ideas??synthsin75 wrote: ↑Fri Jan 28, 2022 7:12 pm Stoopid, quick example.
https://www.mediafire.com/file/u93ifoyk ... c.zip/file
Switch layer interpolation with mesh warp image layers
- hayasidist
Re: Switch layer interpolation with mesh warp image layers
Just ended up being the fastest way to do it.
I've always had problems with Mediafire, but FileDropper (that I usually use for one-off examples) now requires an account. I often have to reload the Mediafire page to get the download to start.hayasidist wrote: ↑Sat Jan 29, 2022 12:37 pmI've been getting errors trying to download this ... "download1334.mediafire.com is not responding" ... tried over the last 3 or so hours - same issue each time.. obviously others are not seeing this - wondering if it's an issue with US-UK traffic?? (my own mediafire account is working ok!) Any ideas??synthsin75 wrote: ↑Fri Jan 28, 2022 7:12 pm Stoopid, quick example.
But I'll just email you the file, Paul.
Please email to me also Wes?
metalshtorm at Gmail
Try this one: https://www13.zippyshare.com/v/RvNKmlVV/file.html
Nice Wes. Just looking at it, specifically between frames 10 and 12, there are some ugly looking frames, probably un noticeable in real time. I guess it's what you expect from interpolation of a single image.
Cheers
D.K
Cheers
D.K
My store on Renderosity:
That's more of an artifact from me making it so quickly. If I'd added one more horizontal line in the mesh grid, it wouldn't stretch the bottom teeth in some of the tweens.
Like I said, stoopid and quick...which is why I'm not hosting the file permanently.
Ahh...but I am merely knit picking. it's brilliant!!!!
D.K
D.K
- hayasidist
getting an error 403 from that one! but the email worked fine. Thanks.synthsin75 wrote: ↑Sat Jan 29, 2022 4:24 pm Try this one: https://www13.zippyshare.com/v/RvNKmlVV/file.html
Man, sounds like UK ISPs really sucks. Hopefully Australia (where Madrobot lives) is a bit better.hayasidist wrote: ↑Sun Jan 30, 2022 7:28 amgetting an error 403 from that one! but the email worked fine. Thanks.synthsin75 wrote: ↑Sat Jan 29, 2022 4:24 pm Try this one: https://www13.zippyshare.com/v/RvNKmlVV/file.html
Trying another host: https://www.sendspace.com/file/ph2ohj
- hayasidist
could be my security settings, but that one just pushes up an advertising screen and tries a pop-up which gets blocked (by MS Edge's pop-up blocker)...synthsin75 wrote: ↑Sun Jan 30, 2022 9:27 am Man, sounds like UK ISPs really sucks. Hopefully Australia (where Madrobot lives) is a bit better.
That last link threw up this warning from AVG.
D.K
D.K
Yes just a little attention to the mesh would fix those distortions, that doesn't change the proof of concept being completely viable.
I realised that this workaround ( using one image to force interpolation to work), may also work with a PSD with the phonemes on different layers.
Each actual switch image could be references of that PSD with a different visible phoneme layer.
Maybe that would allow the addition of new phonemes and remove the necessity to translate the image.
I think there is a bump in the road though.
I don't think a smart mesh for a head turn/ tilt will have any effect on the smart meshes in the switch group, which will break the potential of this to work as brilliantly as it could do.
I think it would take a couple of changes to the way switches work to pull off a production well with this method.
- Meshes inside switch groups need to be able to be effected by smart meshes outside the switch group.
- Bonus feature...Interpolation types. It would be so great to have Bezier motion paths available to the switch keys to do this Stop Mohotion technique
Wholeheartedly agree with this Chuck, I need some degree of head turn for versimilitude or everything will be locked down like Tigtone and kind of defeat the purpose.
Quoted for emphasis. I'm wanting to establish very fast lipsync workflow, interpolation types on the keys would allow a clean up pass banging into the big vowels and so on by adjusting key types. As you say bezier even better, hard run into AAHH and slow out would be straight forward. And doing it on the keys means your lip sync cleanup isnt a deep dive into the timeline trench, adjustment keying, fiddling about moving keys, messing about endlessly - I really want to avoid that.
The single, duplicated image isn't necessary. Just the help me set up the example quickly. The same technique works fine with multiple different images. Just a matter of the mesh morph quality leading into the hard image switching.chucky wrote: ↑Mon Jan 31, 2022 3:08 am Yes just a little attention to the mesh would fix those distortions, that doesn't change the proof of concept being completely viable.
Yeah. First thing I tried was placing a new turn/tilt mesh in the switch, so it could control the nested meshes. But if you select it, you can't see your active switch...and what this mesh is doing to it. Then I tried putting a reference of an external mesh in the switch, so you could see the mesh and what it's doing to the active nested switch mesh. But then switch interpolation of those nested meshes just quits working. Looks like it's an either/or situation ATM.I think there is a bump in the road though.
So it seems which switch group would needs its own turn/tilt mesh controlling its interpolation mesh. This seems to work, and as long as you don't mind setting up the turn/tilt for each switch subgroup, you could then control these by smart bones. Again, excuse the hasty example:
https://drive.google.com/uc?export=down ... R1aCoWrV90
