Spread Keyframes and deselect points
CSCorbridge
Hello all, I haven't animated in 5 years and getting back into it and forgotten so much about this software. Going from AS11 to Moho13 is a big change, need some help. It used to be if I wanted to extend the duration of an animation I could select all keyframes, hold shift, and pull down the timeline and it would evenly space out all the keyframes over a wider duration. No combination of shift/alt/ctl is doing this for me, it just pulls all the keyframes down the timeline in equidistant order, I want them spread. Is there a new technique to accomplish this? Also, say I have a shape with 30 points. If I wanted to select all points then deselect an individual one, I'd hold shift and left click the point to deselect and that no longer works. Can anyone clue me into these changes? More questions to come for sure...
Re: Spread Keyframes and deselect points
As far as I know, it's always been holding alt to drag selected keyframes.
CSCorbridge
Thank you Wes, that worked!!! How about deselecting a single point when all other points of a shape are selected?
Select Point tool, hold alt to remove from selection, shift to add to selection.
Tips for tool modifier keys appear in the Status Bar at the bottom of the window. If you'd rather see this appear under the Tools Options like in ASP 11, you can set this in Moho 13.5.2's Preferences by enabling Tools >Status Bar At Top Of Window. (That's my preference.)
