SS - After Effects Camera Export
SimplSam
Post by SimplSam »
SimplSam's AE Camera Export+ tool allows you to export Camera property & keyframe data to the clipboard, ready for pasting directly to Adobe After Effects.
It was designed as an upgrade / companion to the excellent earlier DS Camera to AE tool - created by David F. Sandberg (aka. ponysmasher) - https://www.dauid.com - discussed here: viewtopic.php?f=12&t=18091
... and complements it with these new & alternate features:
  • Instantly Saves Camera data to the Clipboard (instead of a file); ready for pasting
  • Can be run as a Button or Menu Tool
  • Reduces data size by eliminating redundant keyframes (does not bake multiple keyframes if the property only has a single value)
  • Has a modular code refactor
So ... Why do you need AE Camera Export ?
The tool allows the efficient sharing of Camera configuration and keyframed positioning information from Moho to After Effects, which helps greatly when your animation workflow (finalizing, SFXing or compositing) includes one or more trips from Moho -> Ae. Thus allowing Camera movement & properties to be easily synchronized (one-way).
How do I get set up ?
* To install:
- Download latest release: ss_ae_camera_export (or grab the GitHub release: ss_ae_camera_export.zip)
- Save the 'ss_ae_camera_export.lua' and 'ss_ae_camera_export.png' files to your computer into your <custom>/scripts/tool folder (or under scripts/menu)
- Reload Moho scripts (or Restart Moho)
* To use:
- Run the AE Camera Export+ tool from the Tools palette or Menu location
- If you need to view/amend the data before passing to AE, you can paste into a Excel/Spreadsheet or Text editor
Options & Features
** Currently there are no options
Notes & Limitations
There appears to be a bug in AS11 which limits the size of text passed to the Clipboard to 4096 bytes. Thus AS11 is not fully compatible with this tool.
Because the 'DS Camera to AE' tool fully baked the Camera movement (wrote every possible keyframe), it would always overwrite all previous settings. This tool is keyframe data optimized and only writes required keyframes. So you may occasionally need to clear old-keyframes (deselect the stop-watches or delete keyframes) before use.
Additional Notes:
* Compatible/Tested with MH12+
* Optimized for MH12+
Special Thanks to:
* David F. Sandberg (ponysmasher) -- https://www.dauid.com
* Stan (and the team): MOHO Scripting -- https://mohoscripting.com
* The friendly faces @ Lost Marble Moho forum -- https://www.lostmarble.com/forum/
Stan
Re: SS - After Effects Camera Export
Post by Stan »
Great script, thanks! And special thanks for the awesome level of presentation. Sam, you are the best!
This sounds cool SimplSam. I typically comp my Moho animations in Ae so I should find this very useful. Will give it a try very soon!
Thanks for sharing it.
SimplSam
Post by SimplSam »
Greenlaw wrote: ↑Sat Jan 15, 2022 6:24 pm This sounds cool SimplSam. I typically comp my Moho animations in Ae so I should find this very useful. Will give it a try very soon! ...
I saw AE Camera Export installed on one of your recent videos.. so was wonder whether you (or other) have a use for an AE Camera Import (AE --> Moho). I wrote the initial Import script around the same time as this Export script, but didn't get around to finalising it. So it has sat around collecting virtual dust since then.
lucasfranca
Post by lucasfranca »
SimplSam wrote: ↑Fri Nov 01, 2024 4:54 am
I think it would be very interesting! Sometimes we do need that.
https://youtube.com/animai2D
