Having Problems
Having Problems
When I do my animations and i cross parts of the whole figure the parts that lay on top of each other seem to disappears...
I don't know how...what about you?
Overlap gap tutorial
You need to break down the parts into 2 separate fills.
I've made up an overlap gap tutorial for you.
SWF format, around 400 kB.
Regards, Myles.
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
Comment to Myles
Good tutorial. What other tutorials have you created?
Are they easy to create with Wink? How long did this one take you to make?
Howard
Howard
There are a few extra SWF-based walkthroughs that aren't linked from my site yet (I must set aside some time for updating links).
Assiging a fill - based on part of Tutorial 1.3, for those who prefer a more visual approach.
Selecting shared outline points for adjoining fills - based on part of Tutorial 2.1
Have you got a second fill layer? - another look at fills and a common problem
A quick look at masking - specifically keeping eyelids and pupils inside the eye shape
A chatty look at creating and using Styles
Tutorials are easy and relatively quick to create using Wink - typically anything from about 5 minutes (I think the "Selecting shared outline points for adjoining fills" wasn't much longer than that to create) to about 45 minutes - I think the longest took me about 2 hours - the styles tutorial.
Usually most of the time is caused by my deciding half-way through to use a different example or to take the screenshots again with the toolbar showing or some similar muckup on my part - such as the styles tutorial where I re-did the sample character a couple of times to get the simple shapes that demonstrated the principles without going overboard on the character detail.
Typing the text is the other time-consuming part - especially if you are a 4-fingered typist like me! You can also spend too much time on getting the timing right - I suspect many of my tutorials could do with some revising of the timing, which is why I often just throw in a Next button instead of tweaking the timing.
Wink itself is, like Moho, a pleasure to use - fast, easy, amd reliable. And freeware! (Wink that is, not Moho - but I regard Moho as wonderfully inexpensive for what it does.)
I expect to use Wink for more tutorials in the future.
Regards, Myles.
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
