For complex hairstyles, is there any way to quickly select the bones at the ends of the hair after selecting the Bone at the root of the hair?
https://d.kuku.lu/d7ebc234f
Of course, I am aware of the existence of Bone Selection Buttons, a useful script that registers bones for use.
I want to quickly select a child's bones without registering the bones.
How can I quickly select a bone for the selected child-bone ?
Re: How can I quickly select a bone for the selected child-bone ?
ScriptName = "Syn_SelChildBones"
Syn_SelChildBones = {}
function Syn_SelChildBones:Name()
return "Select Child Bones"
end
function Syn_SelChildBones:Version()
return "0.1"
end
function Syn_SelChildBones:Description()
end
function Syn_SelChildBones:Creator()
return "©2022 J.Wesley Fowler (SynthSin75)"
end
function Syn_SelChildBones:UILabel()
return "SYN: Select Child Bones"
end
-- The guts of this script
function Syn_SelChildBones:IsEnabled(moho)
if (moho:Skeleton()) then
return true
end
return false
end
function Syn_SelChildBones:Run(moho)
moho.document:PrepUndo(moho.layer)
moho.document:SetDirty()
local skel = moho:Skeleton()
local childBones = {}
for i=0, skel:CountBones()-1 do
local bone = skel:Bone(i)
if (skel:IsAncestorSelected(i)) then
table.insert(childBones, bone)
end
end
skel:SelectNone()
for i,v in pairs(childBones) do
v.fSelected = true
end
end
This is a quicker / cleaner solution than I was contemplating.
Only query (which is probably for suizenji) is whether the original selected bone/s should also remain selected. I had assumed that they would. i.e. 'Parents + Descendants' - rather than just 'Descendants'.
Yeah, the picture does seem to leave the first one selected. So this small change will do that:
end
return "0.1"
end
end
end
end
return true
end
return false
end
end
end
--skel:SelectNone()
v.fSelected = true
end
end
Thank you very much.
It was truly a parent + child selection.
This script is very, very easy to use.
Thank you for your great script. Thank you very much.
