DV_SOLO_Layer v2.1
davoodice2
DV_SOLO_Layer v2.1
Post by davoodice2 »
simply Toggle Solo selected layer.
DV_Toggle_solo_layer: for solo selected layer. It preserves current states of layers visibility.
DV_Remove_Visibility_Sets: for Remove script stuff from file.
:roll:
Download
https://www.mediafire.com/file/9n0ymit3 ... 1.zip/file
Re: DV_SOLO_Layer v2.1
I think I know what you mean: when using alt-click to switch to view only selected layer, and then do the same to switch back, you loose the previous view layer settings making the feature undesirable to use. This is your fix to that problem right? Thanks for sharing!
davoodice2
Daxel wrote: ↑Wed Nov 03, 2021 11:57 am I think I know what you mean: when using alt-click to switch to view only selected layer, and then do the same to switch back, you loose the previous view layer settings making the feature undesirable to use. This is your fix to that problem right? Thanks for sharing!
Yes and use alt and click affect on current level of parent. So you have to disable visibility of other layers manually.
But now by run this script every other layers will be hide.
If run it again all layers that were visibile before, will be show again.
davoodice2
Also with first run a layer comp be created to back and forth between solo and unsolo.
I tried it briefly today and it worked fine, pretty cool. Thanks for sharing!
Edit: the "Remove visibility sets", how often do you use it? Maybe I should put it on the menu scripts instead?
davoodice2
Daxel wrote: ↑Sun Nov 14, 2021 10:44 am I tried it briefly today and it worked fine, pretty cool. Thanks for sharing!
Script creates a comp to use in function. This script delete that comp and brings layer states to before use script.i prefer buttons for ability to assign shortkey
EricTheFish
Post by EricTheFish »
Is it possible to mod this script to SOLO multiple selected layers? This would be incredible!
Great script davoodice2, really useful! :)
EricTheFish
www.tech-nique.co.uk
I typically use Layer Comps to do something like this but it sounds like your script simplifies the task by making it a toggle.
I like simpler! Especially for something I typically need only temporarily.
Will give DV_SOLO a try today davoodice2. Thanks for creating and sharing it. :)
davoodice2
Greenlaw wrote: ↑Mon Dec 27, 2021 10:19 am I typically use Layer Comps to do something like this but it sounds like your script simplifies the task by making it a toggle.
be careful ! after solo a layer if you create new layers they will be hide with next toggle! I will work on it later.
davoodice2
EricTheFish wrote: ↑Mon Dec 27, 2021 9:02 am Is it possible to mod this script to SOLO multiple selected layers? This would be incredible!
yes. I will work on that in my free time. thanks.
davoodice2 wrote: ↑Mon Dec 27, 2021 10:24 am be careful ! after solo a layer if you create new layers they will be hide with next toggle! I will work on it later.
Ah! Thanks for the warning. Will watch out for that.
